Re: Time Capsule?
David Breth
>I did a time capsule myself a few years ago for my nephew. Actually, I built him an 18-wheeler that is about a yard long, and under the body of the cab I excavated a hole, in which were crammed trinket-level family items, including things from his grandparents and four great-grandparents.
The wood is poplar, and the way I sealed it, was to put a metal strip over the hole (don't remember what, but I think it was silver-plated brass), and I simply sealed it with screws. The metal strip has stamped on it something like "not to be opened prior to" whatever the date was that would be his 21st birthday.
The "danger" I guess is that one day his curiosity gets the better of him, and he opens it up, but as far as sealing things is concerned, the metal plate should be sufficient.
For your purposes, I would consider a simple clasp lock, held in place not with a lock, but with a zip strip. Many methods, many +/- to each. If you use a lock, and put the key with it - anything can happen to that key over time, and the lock could freeze up. If you glue yourself shut, that's an automatic destruction of the piece. if you leave it unsecured, then the items inside are subject to idle minds. With the zip strip idea, it won't be opened by the casual "look what I found" intruder, but will be fairly easy to open for the person who ultimately is supposed to do so. Though, I guess those plastic strips can get brittle over time.....
Well. I'm sure this was highly useful to you......
For size, it is difficult to know, because of course, you don't know what is going in there. In my case, items included human and cat hair, pins, fishing flies, thimbles. We've had a spaceship floating around for decades with a record player in it. Perhaps you want to consider sizing out the possibility of a CD and a portable CD player going in there, or an envelope with a letter. I'll tell you this much - I wish I had more room for my time capsule than a few square inches of space. Err on the slightly-larger-than-you-think-you-need size for sure.
David B.
