Carved bowl
Carved bowl
Carved bowl
Wolf Kiessling
>I couldn�t make up my mind if to post this on the carving or turning forum so I�ll just post it in both places.
This natural edge catalpa bowl is 13.5� high by 12� dia. The wood is extremely dry and that made this a very difficult project to carve. I have previously carved a lot of catalpa, but that was always green, so this is a first for me. I can only compare it to carving dry, yellow pine. The grain ridges are hard, the wood in between is soft and it has a bad tendency to splinter. I almost abandoned this project.
Anyhow, this represents the completion of the first phase of carving this bowl. My plan is to carve, on the opposite side, another mandella but containing a wolf head instead of Indian head. Then, on the remaining two quarters, I am thinking of two buffalo herds or maybe an elk head with a buffalo herd opposite. I thought I would put this thing up for public scrutiny at this point because, depending on possible comments that I may receive, I may change my mind about how to go about proceeding with the remainder of the work. I will also admit that the Indian head is not my finest work but I don�t think it is quite bad enough to obliterate. The character of the wood caused me problems to the point where I screwed some of the sculpture up to the point where it is impossible to correct. If I proceed along my current plan, the remainder will not be as difficult as the Indian face.
As you can see, there is no finish on the bowl. The reason for that, of course, is that it is not finished. Provided I do finish this project, it will probably be completed with a couple coats of BLO topped off with some coats of danish oil.
If you feel like commenting, feel free. I will not be offended����.
Maybe sad but not offended�����
Re: Carved bowl
Re: Carved bowl - second view
Wolf Kiessling
Re: Carved bowl
Re: Carved bowl - close up
Wolf Kiessling
Re: Carved bowl
Re: Carved bowl - close up (whoops)
Wolf Kiessling
Re: Carved bowl
Re: Wolf- this is OUTSTANDING!! And....
Jamie Donaldson
>I can't believe that carving the end grain is a picnic! Will be interesting to see the completed project, so let us see the results.
Re: Carved bowl
Jerry Whitaker
>Good job!!! Thanks for sharing.
Re: Carved bowl
George Van
>Wolf, this is beautiful! I envy your talent but look forward to the finished product.
Re: Carved bowl
Re: Carved bowl
Glenn Hodges, Nashville, GA
>Wolf, I like this piece probably better than any you have ever posted. The carving of the head the the surrounding pieces make this an example of a eye pleasing balance. Thanks for sharring it with us.
Re: Carved bowl
WOW
Norm Smith in Nova Scotia
Re: Carved bowl
Re: Carved bowl
>I love it. Especially the detail in the hair and some of the other areas.
Re: Carved bowl
Brad Vietje
Ditto that !
Brad Vietje
