We value your privacy.
>I have been turning (learning) for a little over a year now! I recently purchased the Tom Skilton 2" power sanding kit and have begun experimenting with bowls.
Do most of you bowl turners use power sanding alone or a combination of power and hand? Is it reasonable to power sand up to say 320 grit and finish off by hand with finer grits?
Thanks for any and all input!
Best regards,
Wayne
Re: Power sanding in conjunction with hand sanding?
Raymond Overman in SC
>I've found that hand sanding with the grain between the grits help with certain types of wood. Power sanding doesn't solve all the problems. Trouble spots still benefit from hand sanding.
robo hippy
>I started off with hand sanding. After I got the power sander (Sioux/Milwaukee) I used the power sander almost exclusivly. It is a lot faster. When starting, I would switch a lot between the hand and power sanding. The main reason was that the two methods would leave different scratch patterns so it was easier to see what scratches were left from the previous grit. Now, on utility bowls, it is power sanding all the way to 400 grit. I don't go beyond that. I do prefer slower speeds on the lathe, and slower speeds on the sander. For the first grit (usually 120) I will sand with the lathe off, and let the sander turn the bowl while one hand acts as a brake. Once all marks have been removed, I will turn the lathe on at lowest speed and sand the entire thing again. I use pads on the mandril because they are cheaper to replace than the mandril when they wear out. I like the firm pads for the lower grits (up to 220) then the softer pads for the finer grits. I like slower speeds on the lathe (1 to 100 rpm) and on the sander (1200 rpm max speed, and I sand at 600 to 800). I don't do this just because my bowls are warped. The slower speeds seem to work better as far as less heat, longer life of discs and pads, and better removal of marks. There doesn't seem to be any increase of time spent either. Somewhere down the line I hope to turn a bowl that doesn't need sanding, but that still seems to be a long way away.
robo hippy
Wayne Leach-NW Ontario
>Robo Hippy,
Thanks for the detailed and informative reply.
I power sanded the last of 4 cherry salad bowls this afternoon as you suggested and the results look great for functional bowls. This doubles the number of bowls in my career!
Now I must look for a less expensive source for discs or hook and loop sheets.
Will post pics as soon as I figure out how to take them. I am in GA for the winter and do not have my setup from home!
By the way, this is my first experience with cherry and it works and finishes beautifully-love it!
