PM 3520A Remote Switch Questions
Clem Wixted, Jonesboro, AR
>I am about to hook up a home brew remote on/off switch for my 3520A lathe.
First question is the routing of the wire from the head stock to the switch. I am thinking of routing it along the back side of the ways, around the end and below the tail stock and to the switch.
How is the factory switch wiring routed and how long is it?
What type of wire do they use? I am planning on using SJ 2-wire, 16 gauge.
Thanks,
Clem
Re: PM 3520A Remote Switch Questions
>Clem The factory doesn't route the wire. The switch has a magnetic back so you can put it anywhere. I'd guess the cable is about 8 feet or so. It runs through the back of the headdstock where the main input wires go. I don't know the gauge I'd have to check.
Thanks, John
>I think I can take it from what you have given me.
If I can find my digital camera I will take some pictures of the steps in putting this awitch together.
I am using ideas from a numer of sources and even a few of my own.
Clem
