band saw blade tension
eliot d
>I always thought the blade should be under fairly high tension. But at the Baltimore Woodworking Show today I saw several demonstrations of very fancy cutting using a 1/4 Timber Wolf blade under very little tension. You could see the blade twisting all over the place, but it performed beautifully. What's going on? To really rub it in, the lady did the demo with no supports of any kind on the blade.
Re: band saw blade tension
Jim Terry
>Eliot The TimberWolf is a low tension blade. Proper tension is set by backing out the guides and starting the saw with the tension relaxed so that the blade flutters. Apply tension until the flutter just stops. They work great with less stress on the bandsaw due to the low tension.
Jim in NC
Wayne Kuhn
>An article in the Feb 07 Woodworker's Journal by Mark Duginske claims high tension on bandsaw blades is a myth. The article states if you are cranking your bandsaw blade tension high you have other issues with your saw, time for a good tune up.
Re: band saw blade tension *LINK*
Russ Fairfield
>They are doing different things with the band and tension means something different to them.
For us normal folks who restrain the blade in two (2) directions at two (2) places with guide and thrust blocks, we need just enough tension to prevent vibration in the blade and keep it from wandering when we are cutting between the blocks. Anything more than that is too much. Most of us are using more tension than we need, regardless of who made the blade.
It is easy to tell if the tension is right. If we are getting those diagonal vibration lines in a deep cut, the tension is too great. If the blade wanders from side to side in the cut, the tension is tool low. Anything in between is fine. There is something else wrong that tension can't solve if this rule doesn't work.
A good blade that cuts the same on both sides with identically the same sharpness, shape, and set on both sides, will cut with less tension than one that doesn't. There are a lot of cheap blades being used that cut differently on opposite sides, and we crank in more tension and accept poor performance rather than spend a few bucks more on a good blade.
The tension has an additional reason for being there when the guides are removed. In addition to damping vibration and controlling wandering from side to side, the tension has to be sufficient to keep the band on the wheels. It will require MORE tension on the band to do this, and my experience is that it will require at least 50% more. The strength of the welds can now become an important factor. Keeping the blade on the wheels while we are cutting through a piece of wood also requires sharp teeth, balanced teeth, and a tender touch with the feed pressure. I wouldn't be surprized if those folks were also running their saws at a higher RPM than stock.
This higher tension is easy to get with a 1/4" blade, marginal with a 3/8", and impossible with a 1/2" blade on a Delta, Jet, or similar bandsaws with riser blocks.
Personally, I use the tone of the plucked band to determine the tension in the band. 12,500 PSI is between an E-flat and F tone below the bass clef; and gives the same result as the vibration method that Suffolk desctibes. Either way is totallt independent from blade width or the number of teeth.
As for the twisting of the blade, that is all for the show.
Read everything I know about bandsaws at the following link. There is a discussion of guides and tension towards the end of the article.
http://www.woodturnerruss.com/Bandsaw-Tuning.html
Re: Russ et al -bandsaw users.....
Jamie Donaldson
>When I bought a new Minimax S45 last year, I was surprised to read in the IB that the blades should track with the teeth running off the front of the wheels? I have always known that the blade should track near the center of the crown in the rubber bands, but the MM bands are flat? I set up the saw just as the directions specified, and it has worked just fine for a year with my customary 3/8"blade for blank prep. Any comments?
Russ Fairfield
>Jamie,
If you were to check the wheels, you should find that they are slightly "crossed", and it effect are creating the same hill that you find on the crowned wheels that are supposed to be running in the same plane.
Old Delta saws ran with the teeth on wide blades hanging over the edge of the wheel. The new Delta (and everyone elses) saws have a flanged wheel that will wipe out one side of the blade if we were to try doing that. I preferred the old wheels.
