Stihl problem
Stihl problem
Stihl problem
Ed Moore
>Below I described how my Stihl MS310 had a crankshaft problem after 3 1/2 years of moderate use. Actually, I think it was the connecting rod that cracked and a bearing was slipping that caused the engine to bind. It was declared economically unrepairable.
It was suggested that I contact Stihl and see if they might be interested in ameliorating the situation. I got on their website and sent them an e-mail explaining the situation. I did not suggest a solution, but indicated my disappointment. I also pointed out that I had upgraded to an MS361.
Yesterday, for a disabled neighbor, I sawed up most of the limbs of a large poplar tree that fell over a few months ago. I DO like the new saw and the additional power. And sawing poplar is a lot easier than red oak. ;^D
I will let you know of the response from Stihl, if any. In the e-mail I mentioned the discussion here.
Ed
Re: Stihl problem
You sawed the limbs of your ......
>Disabled neighbor? Mad man! I'm telling Ellis! You should be banned from the Island.
Re: Stihl problem
Rough old geezer, aren't I? ;^D
Ed Moore
Re: Stihl problem
Stihl steps up to plate
Ed Moore
>I have been in touch with Stihl and Stihl has stepped up to the plate and offered to replace the complete crankshaft assembly. I believe that this is fair and generous for a saw that is 3 1/2 years old with a one year warranty. There were some earlier misunderstandings about costs because of the distinction between "crankshaft" and "crankshaft assembly". I think there is a big $$$ difference between them. Now I must find out how much the labor will be to reassemble the saw. I will report back if there is a happy ending to my chainsaw saga.
Ed
Re: Stihl problem
Re: Stihl steps up to plate
Mike Nelson
>Glad to hear it worked out Ed. I would think the cost would be fairly low for your repairman to reassemble the saw. If not you should be able to find a schematic and even repair instructions on the web. Putting it back together shouldn't be all that hard, just remember to oil all moving parts. Mike
Re: Stihl problem
Expected cost
Ed Moore
>Mike,
Thanks for the original suggestion. Stihl offered to provide a new crankcase assembly. My expected cost is about $160, which is fair. This is to be confirmed on Monday after the dealer chats with the Stihl tech rep and his repair guy.
There is NO WAY I would attempt to take the bag of parts and reassemble them. ;^D
Ed
