Wolverine - Make your own - alternatives?
Joe in a Cleveland suburb
>Hi.
I wonder over here once or twice a year since that's about how often I use my little Jet. I was making a feeble attempt at turning some Shaker type knobs over the weekend and decided I'm sure my little spindle gouge is way past due for sharpening.
I brought out my Ernie Conover tape to review sharpening. Not much detail was provided though other than showing the use of the Wolverine jig. I also remember the visit I had with Jim Pugh and he showed me some sharpening tips. Anyway, I checked the price of the Wolverine. For the small amount of turning I do right now, I don't want to buy one.
I did some searches but didn't really find what I am looking for. I remember seeing detailed plans for making your own Wolverine type jig. Anybody have a link to such plans?
Are there any other jigs other than the Wolverine that may be a little less $$? There's got to be alternatives.
Thanks.
Joe
Re: Wolverine - Make your own - alternatives?
That, and much more! *LINK*
Clem Wixted, Jonesboro, AR
>Here is a great site, not only for sharpening, but also for many turning related items. Darrell has a number of shop made articles for turning. And, he's a nice guy that I have never met.
Darrell Feltmates Site
Wow. Perfect. Thank you.
Re: Wolverine - Make your own - alternatives? *LINK*
>Joe order the fundamentals of sharpening from the AAW site. It covers 4 different turners and their methods of sharpening. Then you can pick the best one that works for you.
http://www.woodturner.org/products/videos/
bob davis
>joe,penn stste has a wolverine copy for a much lower price..
Dennis Yoder
>IMHO the Penn state in not in the same ballpark with the Wolverine. DAMHIK. Dennis Y
David Walser
>Not really on topic -- which is making your own jig -- but another alternative to the Wolverine is the Woodcut jig. The Woodcut and the Wolverine work the same way, but the Woodcut takes up much less space. This is an advantage in small shops. The disadvantage is Woodcut may take a little more time to use. (The Woodcut system requires each tool to be mounted in Woodcut's equivalent of Wolverine's vari-grind.) The Woodcut jig tends to cost less, too. Here's a link to the Woodcut jig at Craft Supplies USA:
http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=903-1130
Bill Crommett
>I made my own out of a couple of pieces of square tubing and a small piece of angle ion.
Allen Neighbors
>You can sharpen a spindle gouge on a belt sander that is running verticle. Clamp a board with a v-block on it at the appropriate distance from the belt. Rotate the Spindle gouge both directions from center. Hone.
If you want pics of my permanent setup for Spindle gouges and chisels, I'll post one.
HTH,
Joe Flemig
>Joe,
If you go to the San Diego Woodturners' website (www.sdwt.org) there is a sharpening handout in the tips section. I explain how to freehand sharpen your gouges without the Varigrind type jig.
Joe Fleming - San Diego
Ron McKinley
>Went there and couldn't find it. Could you give a direct link? Thanks........Ron
>Ron,
I believe this link to a PDF is it.
http://www.sdwt.org/forms/Grind20061104.pdf
Joe
>Sure, I'd like to see a pic.
Thanks,
Joe
Re: Verticle belt sharpener
Allen Neighbors
>This is an old Sears 6X48 belt sander... you could use a smaller one.
You can see that I used a piece of plywood for the motor mount, so I could swing the motor around, making the sander run 'up' instead of 'down'.
I laminated two thicknesses of baltic birch ply together to make the V-Block table. The two rows of holes are 4" apart. The sets of holes range from 1/2" apart next to the belt, to 1-1/2" apart at the farthest point from the sander. (clear as mud?). The V-block has 1/4" pins epoxied in place. The pins are made from smooth shank 1/4" bolts (threads removed - ends rounded)... spaced to fit perfectly in each set of holes. I marked the holes used for certain tools with a sharpie.
If I had it to do over, I would not make the v-block table as high as it is. I'd put it down on the sander's stand. That would let me sharpen a longer handled tool.
Re: V-Block Table - Close up
Allen Neighbors
Brad Vietje
Brad Vietje
>Excellent, Allen.
Glad to see your sharpener. I made one almost the same, but using a 12" disk sander, and the tools are sharpened on the UP side of the disk. For my longer tools, I added a vertical board with paired holes going down the left side toward the floor at a small angle to get the tool tips onto the disk (belt) -- it doubles as a support leg for the horizontal board.
If it's easy to switch the motor mount around ro reverse the rotation (to go UP), I strongly suggest you try it sometime -- you might be very pleased with the results.
Safe spinning,
Brad Vietje
Newbury, VT
Joe Flemig
>We have been having website problems. www.sdwt.org will eventually work.
Joe
Thanks Allen
Re: It is going up. I switched the motor.
Allen Neighbors
Jeff
>I have the wolverine system but do all of my sharpening by hand with the support of the platform. Just take light cuts and follow the profile of the tool you are sharpening.
Here's the one I made
Garrett in Victoria BC
>Here's one I made a few years ago out of scraps. Just a tube within a tube and a holder on the end.
You could do the same thing out of wood by making a plywood base, and routing a slot in a matching piece so that one slides over the other.
Cheers, Garrett
Re: Here's the one I made *LINK*
Darrell Feltmate
>Garrett
I like it. Here is mine. There are videos of it on use on my web site under sharpening.
Around the Woods
