We value your privacy.
>I formerly worked in a shop that made continuous-bow windsor chairs. The ash bows were steamed, then bent around a form, then secured with a wood strip tacked to the ends. When dry, the strip is removed, the bows remained bent.
I've been messing with a similar concept on bowls... I'be been tacking a strip across the top of the bowls to prevent them from distorting. So far, so good. I've only done a few but no failures, esp. the cherry bowls which are prone to quite a bit of movement. I've lost some cherry pieces in the past due to too much out-of-round. May be worth a try in your shop...
>Keith, thanks for the hint. I may be trying that soon, as I'm going to attempt to do a fair amount of roughing and drying, after asking the WC members about their rough-turned bowls.
>I have done a few Windsor chairs and really was jazzed by the wood bending. It was my favorite part. I have never thought of that with bowls. I just pulled out some old bowls that have warped oval and you have given me a thought. Please add comments as to your thoughts on this process. Anyone try this? I have similar issues with cherry when I did not let it dry sufficiently.
>I like the idea Keith, you made me think of other applications where I may �want� to cause a certain warp and your idea will be a big help. I will try it soon. Thanks for posting.
>Try it and keep me informed.... I initially turned some fairly large cherry bowls, with 1" wall thickness. They began to warp, and I soon realized they would be useless unless I did something drastic. So, I put a pipe clamp across the top to stop the warping...every day or so, I added a bit of tension until they were round again, and then left them to observe. I removed the clamps, then added the tack strip....presto. NOw, I just add the strip when I see noticable warp....on the largest diameter of the piece.
Back when I was turning a lot of salad bowls, I had very few problems with warp and cracking. I attribute that to some of the things that I was doing at the time.
The bowls were turned using pipe floor-flanges for faceplates. The flange was attached to the bottom of the wood with 8 lag screws, and it stayed there through rough turning, drying, 2nd turning, and finishing. It wasn't removed until I was ready to turn and finish the bottom. The flange held the bottom together and its presence reduced the rate of moisture loss from the thicker bottom area. There was a lot of gunk under the flanges, but there was no bottom cracking.
All bowls were dried in an separate room and the only thing I did was maintain a temperature of 85F with a gas heater during the cold months, and let the humidity be whatever it wanted to be.
All bowls were placed rim down on wet newspaper (16 sheets thick after folding) on a drying rack. The wet paper prevented premature drying (and cracking) on the rim of the bowl. I inspected the bowls every few days and re-wet the paper if there was any sign of cracking around the rim as the bowl dried.
Whenever one of them looked like it was wanting to go too far out of round, I strung a couple band-clamps together and put the squeeze on it. This seemed to bring them under control and stop the movement. I saved a lot of bowls this way.
Of course, I had already learned that people don't buy bowls that were made from bad wood, so I learned not to turn any bad wood. I made a lot of "art" bowls during that learning process.
I do things a bit different now that I make fewer bowls. I use a chuck rather than a faceplate, and I turn the bowl to finished thickness and rough sand while the wood is still wet. Then I sand and finish the bowl after it has dried. I still place them face down on wet newspaper to keep the rim from cracking, and I still use the band-clamps when one of them wants to get too wild with the warp. Redwood, Cedar, and Cottonwood gets the submarine finish treatment by soaking them for a few days in a tub of oil finish before they are set aside to dry.
I would have more cracking in the bottoms now, but using a chuck allows the foot thickness to be less, or better yet a recess, and that reduces the mass at the base and keeps the cracking to an acceptable level that can usually be repaired.
Warp is not the issue that it used to be because the market has changed. Most people are accepting the fact that wood is wood, and that warp is OK as long as the bottom is flat and the bowl doesn't rock when it sits on the table. For those that don't understand that and want perfection, I still make a few of them the old way.
>I usually don't have a problem with warped bowls myself, especially if it's a green turned piece. However, if it is going to be turned green, then again dry, some bowl blanks warp so severely that they become unusable. This failure rate is at least 50 percent in cherry or elm, as examples. At this point, these warped pieces have been a complete waste of time....which I don't have any to spare.
There are times when I capitolize on wood's tendency to warp; for instance when I intentionally want uneven wall thickness...I allow a piece to warp at will, then true up the inside for the effect I want. One reason would be a heavy side which would allow some carving. Photos of such pieces will be coming shortly.
>Russ, I was just out in the shop this afternoon and had a couple hours with no particular project begging for my attention, so I decided to finish turn a couple of rough out bowls I had laying around. I rough turned them (cherry), soaked in alcohol and just threw them on the shelves till I get around to them. They were distorted as expected, but no cracks. I got to thinking about your post (I read it this morning) as I was re-tuning these and it got me thinking about your process. If you turn to finish and rough sand the bowls, how do you do final sanding and true up the foot or base?? Do you finish sand off the lathe, or power sand with the bowl turning really slow?? Do you re-mount the bowl.
I'm like you, and only turn bowls now and then but I still like the process. I usually mount using a chuck with a tenon. I may reconsider that since a recess makes a little more sense regarding the drying process and cracking, but it does limit the option of a footed bowl.
