chimney ornament
>As you saw below I've been trying to learn to make a brick pattern in wood. this is the latest attempt. I thought it might be fun to make a brick and concrete ornament.
chimney ornament
Re: chimney ornament
Mike Brazeau
>That is very cool John. I like the small square pyramid portions as well. Did you rout them or do by hand? The creative side of your brain never stops.
Mike
>I worried over how to do the squares and then tried the dremel. To slow and too easy to damage the round portions above. Then I tried a small wood fine. Again it was too hard to control and actually hold the finial at the same time. Since I do some carving I thought I would just switch to that. Bummer I picked some really hard dogwood for this finial.
Then it hit me. I have a scroll saw, so I roughed them out with this and fine tuned them with a chip carving knife and 3/8" chisel. Wow that was a lot harder than it should have been if I'd thought about it in advance.
