Spindle Steady
Spindle Steady
Spindle Steady
Greg Haugen
>I was wondering if a Spindle Steady is all what its cracked up to be. I know there are a few options, like Woodcrafts and Oneways. I just didn't know if they do what they are supposed to do. Worth it?
Thanks
Greg
Re: Spindle Steady
Re: Spindle Steady
John Kyler
>I have the Oneway. I did some spindles that were 1 3/8" x 39" and it worked well to reduce deflection. I replaced the wheels with roller blade wheels for a narrower contact.
John
Re: Spindle Steady
Absolutely...
Peter Teubel
>It's indispensable for long thin spindles. Holds the work steady (no pun intended) and reduces/eliminates whip. Personally, I like (and have) the Oneway version.
Re: Spindle Steady
Re: Spindle Steady
David Walser
>Greg,
Are they worth it? It depends on the type of turning you do. Some kind of steady is all but required for long, thin, spindles. You can make your own with the wheels from a pair of cast off rollerblades. (You can also use string, instead of wheels.) The advantage of buying a steady from Oneway or someone else is the time and effort saved in making your own. Only you can say if that's worth it. Some prefer to use their available time for turning. Others enjoy using tools they've made as much or more as turning itself. Your call.
Re: Spindle Steady
Re: Spindle Steady
>Depends on how long and how thin. When I was starting turning I really could have used one. In fact I did make a few makeshift ones to help out. Now that I've turned a few hundred spindles I can usually turn them by steadying by hand and proper tool usage. that's on things like chair legs and stair ballusters. Longer and thinner I'd probably build another steady.
Re: Spindle Steady
Re: Spindle Steady
Allen Neighbors
>Ditto what the others said. I don't do spindles (yet) but I made my own steadyrest, using 3/8 allthread, wood, and rollerblade wheels. It could be used for some spindles, just not thinner than about 1.5" dia. It would be worth the trouble.
Re: Spindle Steady
"ShopNotes" steady plans???
Greg Haugen
>A fellow club member mentioned that ShopNotes had plans for a Steady in one of their issues. Does anyone know what issue????
Greg
Re: Spindle Steady
Re: Spindle Steady *LINK*
Mike Brazeau
>In the left side of this picture is one I made in 2001 for my old Delta Rockwell Homecraft and updated for my Oneway 2436 by replacing the vertical portion. I had some pieces of anodized aluminum that worked very well for supports for the roller blade wheels. This is easy to move which you usually have to do for spindle work. The rests made with all-thread are great for vases but here all you want to do is absorb some of the vibration. I have used as a bowl rest also. It is very simple construction with an extra layer of plywood at the base to secure the vertical piece. Lots of glue and some brads. I could takes some additional pics if desired and post.
Mike
The Joy of Wood
Re: Spindle Steady
Re: Spindle Steady
Ken Grunke from SW WI
>Greg, I have been turning those railing spindles for our club buddy Jim Cox and for a production situation, I don't think a steady rest is worth the bother. It would have doubled, or even tripled the time spent on each piece and just be in the way.
I take a final pass (or three) with a very light cut, and an overhand grip on the spindle with my left hand which is also guiding the skew, to flatten the "ornate spiral carving" resulting from spindle whip. The amount of wood to take off is very minimal, just a thin shaving. The skew is scary sharp after being honed and polished with white diamond compound.
But I *am* fabricating a steady rest for turning small percussion drums, so I can hollow them while they're bolted to a faceplate. The Jet 1236 just won't handle a 10" diam. piece overhanging 116-20" out from the spindle without screaming for mercy! It's a two-post unit using 3/4" threaded rod, and steel bar for the framework. I'm hoping it will come in handy for larger diameter work such as vases, and other hollow vessels.
Re: Spindle Steady
Re: Spindle Steady
Peter Hyde
>This will do spindles or hollow forms. This is using a Termite to the limit!
Re: Spindle Steady
Re: Spindle Steady
Russ Fairfield
>Take a look at the spindle steady rest in Ernie Co0nover's, "The Lathe Book". I have used this type of rest for many years because I prefer it to anything I can buy on the market. It has the advantage of being open on the front so you can turn through it, and it is self adjusting. It doesn't have the positive grip of the 3-wheeled rests, but you don't need that kind of a grip for most things.
Re: Spindle Steady
Re: Spindle Steady
Rich Egan
>Greg:
I own a one-way steady and like it. It's quite heavy and well - built. You are welcome to try it if you like. You may have to make a clamp block to fit your lathe bed - no big deal.
