Timberwolf AS 3/8" x 3tpi blade & sled
Dominic Greco in Richboro PA
>Eliot,
Funny you should mention this now. I just got finished cutting an 7" dia. apple log on my band saw. I just cut right down the middle, centered on the pith. This is done free hand without using a fence.
I then flatten this cut face with my jointer. But you could also use a scrub plane to get it reasonably flat. Then I use place the flat section against the bandsaw fence and saw off the pith. From then it's an east matter to saw up slabs.
If you try to saw a wet log with a resaw blade, you may find that it will bind up and often catch. I found that using a AS 3/8"x 3 TPI Timberwolf blade from Suffolk Machinery really helps when sawing up "wet" wood. This blade is made for cutting wet wood and features specially set teeth to clear the sawdust. If you call Suffolk, ask to talk to a tech and they will steer you in the right directions. They are very helpful.
When the log is prone to rolling, or too big to handle comfortably, I use a simple down and dirty sled. The design came from somewhere in the FWW archives. It's just a (2) 5" wide x 18" long pieces of 3/4" plywood that have been assembled into an "L" (so you get a 5"x5"x18" long angle). A couple of 2" tall gussets at either end help support the fence. Simple lay your log on a flat surface, and place the fence along side. Use some 1 1/2" (or there abouts) long machine screws to temporarily fasten the log to your fence. Now bring this over to the bandsaw and cut the log along the pith like above. The rest is as I described above.
Good luck!
See ya around,
Dominic
