bandsaw problem
bandsaw problem
bandsaw problem
Jerry in Indy
>I have searched the archives and haven't found much that will help me so I want to survey this group to get help for my problem. I have a fairly new Jet band saw which I purchased mainly to cut turning blanks with. I am having trouble keeping the two small plastic guide blocks that are suppose to keep the blade cutting staight from wearing out too quickly thus letting the blade wander all over the place. I have tried moving them up and moving them back with no difference in the results. I believe the proper place is just behind the teeth but any place I put them they melt quiclkly. Does anyone have a suggestion? Also what is the best blade for cutting blanks? Thanks in advance.
Re: bandsaw problem
Re: bandsaw problem
Mike Nelson
>Jerry, I had the same problem with my delta, you can order the ball bearing guides but they are very expensive. I read where someone was using oak cut the same size and soaked in oil, I'm using them now and so far works great.
Re: bandsaw problem
Re: bandsaw problem
jwoodwright
>I've been using corian blocks on my Jet 14" for 7 yrs or so. Need to be "dressed" on a disk sander every month or so. On my 4th set...
Re: bandsaw problem
Re: bandsaw problem
Jerry in Indy
>You didn't say, but can we assume you made them?
Re: bandsaw problem
Re: bandsaw problem
Ron in Drums PA
>For years I've used maple dowels with great success.
I recently switched over to lignum vitae because someone gave me some.
Re: bandsaw problem
Re: bandsaw problem
Mac
>I have used the cool blocks(brand) for a number of years now, and have been happy with them. They do require dressing on a sanding disc occasionally.As for blades, I have had good service from the Woodcraft house brand ones,about $12 each,so cheap that you use them till they are starting to get dull and then toss them.Please dont use dull ones as that is the main cause of accidents on the band saw.Any width between 1/4" and 3/8", three or four teeth per inch will work fine for cutting blanks.Count your fingers every night before you leave the shop.Take care.....
Re: bandsaw problem
Re: bandsaw problem
Steve Worcester
>I would try the ceramic blocks these guys make.
http://www.spaceageceramicguideblocks.com/
I haven't tried them, but use ceramics on my Laguna monster. The only thing that will wreck them is hitting the teeth on them (and take the set out of the blade.)
Steve Worcester
www.turningwood.com
Re: bandsaw problem
Re: bandsaw problem
>Jerry You may need more tension on the blade and less force pushing into the cut. Ideally the guide blocks aren't even used. I know we all force the cut a little especially as the blade gets duller. This cause the blade to want to wander and consequently they rub the guide blocks. With the right tension on the blade, the right feed rate and sharp blade you will barely touch the guide blocks.
I have the bearing guide blocks because they came with my saw but I don't recommend them for cutting green wood. The green chips get stuck to the bearings and make them lumpy. It's hard to clean this stuff off. It's OK for cutting more green wood but if you want to stop and do some serious cutting like resawing you have to clean the bearings off.
I had cool blocks on my last bandsaw and liked them a lot. I would have to square them occasionally but that doesn't take very long.
Re: bandsaw problem
Re: bandsaw problem
bob davis
>i havebeen using oak for 9 years on my jet..wears very slowly..when wear is evident. remove and square up on disc sander..did not soak in oil but i lbricate my blades frequently with PAM as su gested by timberwolf
Re: bandsaw problem
Re: bandsaw problem
Jeff
>I replaced the blocks that came with my Jet bandsaw with the cool blocks. They do wear but they also perform well. You can but them right up to the blade for good support.
Re: bandsaw problem
Re: bandsaw problem
Bill Howatt
>I look upon the blocks as another shop consumable but they shouldn't be wearing away real fast. I have cool blocks but when they are worn out I am going to try and make replacements from some UHMW plastic cut-offs I have. I think I bought them from Lee Valley a long time ago.
Bill
Re: bandsaw problem
Re: bandsaw problem
Chuck Engstrom
>As far as blades for cutting green blanks, lots of folks like the 3/8"-3AS Timberwolf blade from Suffolk Machinery, phone 1(800) 234-7297. I have had fairly good luck resharpening them once or twice as described by Steve Russell.
Just a satified customer.
Chuck Engstrom
Re: bandsaw problem
Re: bandsaw problem
>I use the Band Rollers from Ittura Designs. Small bearings mounted in metal holders that fit in the original guides. Seem to be working well.
I use a half inch 3 tpi hook tooth blade for most every thing. I made a slider for the slot in the saw that has indexing holes in it. I start many bowls using the woodworm screw in the chuck, so I drill a hole for the screw in the blank and then sit it on the pin in the slider. Often I don't bother to make the blank round but just slide the set up through the saw about eight times to make it an octagon and then knock the corners off on the lathe. If I were doing lots of blanks, I might switch to a narrower blade and cut round blanks, but its such a PITA to change the blade and set it up and then change it back, I don't do it, most of the time.
Re: bandsaw problem
Re: bandsaw problem
Fog Tanner
>Steve,
I bought a set of them for my Jet. They don't wear, but I found a problem in keeping them in place. They have no give to them and the screw replies on pressure alone. I have to use a pair of pliers to tighten and loosen the screws.
I solved the problem by moving up to a 16" MiniMax which has Euro style guides.
Re: bandsaw problem
Re: bandsaw problem
eaglesc
>Lignum vitae.
YOu can "bury the band" in them.
Ball bearing wheels only have a tangent contact point, thumbs down, just a waste of money.
