making bricks
making bricks
making bricks
>It's been a typical day for me with about 6 projects going at once. This is one I'm working on. I have a piece I'm designing that needs bricks so I spent the day off and on working on how to do it. This is no 3.
Here's the process so far. Turn and sand, raise the grain and sand. Dye the wood. Spray with lacquer. Put it back on the lathe and turn the horizontal grooves. Use a custom made woodburning point to cut/burn the vertical lines. Fill the lines with drywall mud. Wipe it away and then coat with lacquer.
It's not bad but I'm having trouble with the vertical lines. The burner isn't making the lines very deep so you have to be really careful when cleaning the drywall mud. It also leaves a slight burned residue that shows. I may be able to sand the burn off since it's kind of on the top layer of lacquer.
On the final one I will spend more time with the dye and my airbrush to alter the color of some of the bricks. I may add some tooth brush type splatter spots as well. I'll probably dye the drywall mud a light gray as well.
Anyone have any suggestions on improving this method. I'm going to sharpen the burning tip more to see if it will penetrate the wood deeper. I don't want to turn the heat up anymore because it will scortch the lacquer more. I tried not sealing it with lacquer but the mud starts filling in any grain or small holes in the wood and dilutes the color of the bricks.
I'll try another test or two tomorrow. I may make a Christmas ornament. The look of brick in a really thin light ornament should be fun. Maybe I can make a chimney with a santa. :)
Re: making bricks
Re: making bricks
Bob Fawcett
>How about a V carving tool.
Re: making bricks
Re: making bricks
John Bussom
>John,
You didn't give the size of this project other than ornament size!
If it weer my project I would probably do the horizontal lines on my mini lathe then take it to my older lathe that has index capability and rig up my mini grinder (dremel style) and do the verticles using the index.
How are you getting your spacing now on the verticles?
John
Re: making bricks
Re: making bricks
Brian Simmons, Heflin, AL
>Have you considered something like a trim router? Lock the spindle in place and slide/guide the router along the tool rest. It could also be used for the horizontal lines. Using the same method and bit for both should increase consistancy.
Good luck.
Re: making bricks
Re: making bricks
>Bob I'm going to try a V tool today but I not very good with that tool. I can cut straight lines and curved lines but always have trouble stopping the cut right where I want. I guess it isn't sharp enough. That's a tough tool for me to sharpen correctly.
Re: making bricks
Re: making bricks
>John They will probably vary in size depending on the project. What I'm planning for this one is about 5/32 to 3/8 tall. I use an indexer and will probably look at using the Dremel to cut the vertical grooves. I built another table for the lathe that will support the Dremel.
Re: making bricks
Re: making bricks
>Brian I'm using a trim router now with a custom made support to cut some lines but I don't have a bit for the trim router that will cut lines that small. I'm going to try the Dremel.
Re: making bricks
Re: making bricks
Bob Fawcett
>Try cutting from both ends. This may help you stop. I find I do better with multiple small cuts.
Re: making bricks
Re: making bricks
John Bussom
>Ha ha John, I make some small things but earrings I don't thiink so, 3/8's tall, how many bricks you planning to put on this, if it was me I would need to use my magnifier on the whole thing!
I'm thinking maybe I could handle it if the bricks were 3/8's!
Good luck and let me know how you make out!
Happy New Year
John
Re: making bricks
Re: making bricks
>John I meant the bricks would be 1/4 to 3/8 tall not the whole project, although that might be something to shoot for. I just made new miniature tools for my quest to make the smallest goblet. 1/4" ornament wouldn't be out of line, but now adding bricks to that 1/4" ornament might be a challenge. Then of course thiers the turned fly that would sit on the bricks. :)
Re: making bricks
A Very Sharp Chisel
Jorge Castaneda
>As wide as the brick and tap - tap, voila, a clean line!
John, I think this will work easier and faster than the burner, one tap from the left, next one from the right.
Jorge
Re: making bricks
Re: A Very Sharp Chisel
John Bussom
>Jorge,
By golly I think that is a great idea, with the horizontal put in first then using those mini carving tools......... should work great! I like it better than usin a dremmel!
John B
Re: making bricks
>Jorge I have considered using a chip carving knife. same thing, sorta, one cut from the left one from the right. I think these will be slower than the burner but the lines will be cleaner. I'll probably try that later in the week.
Re: making bricks
Re: making bricks
eaglesc
>Bloodwood and aspen would be a lot quicker
