We value your privacy.
>I'm considering a second chuck along with my current Talon.....and the SN2 chuck interests me as well. I feel a bit odd asking this question since I know lots of people like the tool, but it would appear that it might not be able to be torqued down as tightly as the Oneway system with their drill chuck feature. I have allen wrenches that I use and when I really twist hard.....they "twist" a bit. Maybe I'm misreading the diameter of the allen wrench that TechknaTool uses.
There is no problem tightening the chuck about as much as the wood can handle, but I'd have to ask why you wouldn;t get either another Talon ? There are a few chucks that can swap jaws (usually with some modification), but you might find it a lot more useful to have one chuck set up with #2 jaws, and another with #3, or with jumbo jaws for reversing flat-top bowls. Seems to me that switching brands could get expensive having to get all new jaw sets.
BTW I use both Oneway and Teknatool chucks, and like them both, so I'm not just siding with one brand -- I'd rather have 2 Supernova-2's or 2 Talon's than one of each. Both are top-shelf in quality, and I don't think either is much better than the other (I wouldn't say the same of the original Supernova, which is inferior to both).
>I have a Super Nova 2 and a Super Nova. I like the Allen key arrangement on the Super Nova 2 much better than the proprietary geared key on the Super Nova. I think the SN2 is a much better chuck.....heavier.... enclosed back........it's not perfect though.
The supplied Allen wrench is of the ball-end variety. Because of this configuration, there is little contact area between the ball-end and the socket on the chuck it fits into. A friend of mine had to send his chuck back and have the sockets replaced because of premature and excessive wear. A standard Allen wrench works much better and should cause less wear, as there is a lot more contact area. Now, to answer your question, I think the SN2 should be able to snug up just fine on just about any piece of wood you might want to turn, but I'd use a standard Allen wrench though.
>I second Barry's statement about the allen wrench, if you get a Supernova 2, the first thing to do is to grind off the ball at the tip an the result is a regular T handle allen wrench, a lot better that way.
