Using a hook tool? (long)
Carole Valentine
>I have a Kelton hook tool and am having some trouble learning to use it. Hoping someone can shed some light. First of all, I am assuming that a hook tool is to be used on end grain. Right? I have mounted a piece of very dry magnolia to practice on, but at this rate it would take me 2 weeks to hollow the piece. Should the tool only be used for fine finishing cuts? I looked at Darrell Feltmate's video on using a hook tool and that got me started, but it still seems very difficult to use. I will say that the very light cuts I can get with it leave an extremely smooth finish on endgrain, but I know I must be doing something wrong because it takes so much effort even though it has been honed and seems to be very sharp. I have a feeling that this is one of those things that needs "in-person" instruction. :( I am posting below a few photos of the tool, the shavings I am getting, etc. The angle of the tool can be adjusted somewhat and the set screw either tightened or loosened a bit as a sort of clutch in the event of a catch. Any tips are appreciated.
Re: Using a hook tool? (long)
Shavings
Carole Valentine
Tool profile - side
Carole Valentine
Tool profile - top
Carole Valentine
Cutting
Carole Valentine
>This is not exactly the presentation - trying to hold the tool and take a pic at the same time.
Results
Carole Valentine
Re: Using a hook tool? (long) *LINK*
Bob Fawcett
>Carol,
This may not be relevant. I have a termite tool. Its a complete ring, not a hook, but your hook looks like a ring with a segment missing.
Termite
Brian McInturff in SC
>Carol,
I was watching the 2005 AAW Symposium Techiques video just the other day and Andre Martel was demonstrating his hook tool which has a patent. He rolled it counterclockwise until he found the "sweet spot" and was able to to guide it one handed. From the look of your pic you have it to high and rolled to far to the right. I hope I described that where you could understand. The cutting portion is almost in the center of the curve but not quite. He was taking some significant shavings with his. Brian
Re: Cutting
Ed Kelle
>I could be completely wrong, as I do not have one of these, but I think the hook should be pointing to the left in the same direction as those swan neck hollowers. Basing this on the pics of Robin Wood using a handmade hook tools on a pole lathe in Bowl Turning Techniques Masterclass book.
Leppikallio
>Everything seems to be fine, you are using it right I think and I assume the tool is Sharp. However my guess is that answer is "piece of very dry magnolia to practice on". Have you tried some green wood? Anyway it should be much more nice even relaxing and fun to turn green wood with hook. Basically tool itself is just ring cutter like Termite and is used pretty much sameway...
Just my guess of course...
Brad Vietje
Re: Cutting
Brad Vietje
>HI Carole,
Great job taking a picture while cutting one-handed !
I use the Martel hook tool a lot, and yours looks very similar, but without the compound curve. I can't see real well -- does this tool have two bevels and drill its own hole (like the Martel) ? These are definately for end grain only. My first suggestion would be to try working with green wood if you have any to practice on, as it cuts much easier.
It looks as if you need to angle the tool handle just a bit more to the left -- toward you-- to engage the edge a bit more. You might also want a little less rotation clockwise for a less aggressive cut.
The neutral position for this tool will be at center, with the edge to the left, and the curved blade upright (and curved toward you). To start a cut you can angle the handle slightly toward you, which will engage the blade. You can also rotate the tool slightly clockwise. To start a cut you may need to lower the tip just a bit. I usually do all three to start a cut, returning to center height once I pick up a curl. A less aggressive cut would be small increments in these three planes, while larger changes are more aggressive.
I have used my Martel Hook Tool and the simpler Wolok Hook Tool on dry, hard species, but green wood can produce nice long shavings. Good luck with this great-looking new tool !
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Martel Pics *LINK*
Brad Vietje
>Carole,
The link shows some photos of the Martel Hook Tool in action -- hope it helps you out.
Safe spinning,
Brad Vietje
Newbury, VT
Martel Hook Tool in Action
Re: Cutting
Carole Valentine
>Hi Brad,
I wasn't actually cutting during that pic! LOL And I couldn't seem to hold the tool at the actual cutting angle and snap a pic at the same time. Spastic, I know. The tool does have bevels on both sides and I think there must be a way to go from the rim to center as well as from center to rim as I have been doing. As far as drilling it's own hole, I think it probably could but until I can get to meet with someone experienced in it's use, I am not going to try that. I can't afford to get hurt right now with my Mom ill!
Just a suggestion...
Peter Teubel
>I've used hook tools in the past (Martel and homemade) and they can hollow quite fast if you got a strong arm (a catch is just an uncontrolled deep cut... ;). Based on your picture, it looks like the working edge (red) isn't sharp. The apex of the curve is where the work happens.
Think I am getting it (slowly)
Carole Valentine
>I changed the angle in the holder a bit and raised the toolrest a tad so I had a bit more of a downward angle. I am completely amazed at the cut this Kelton tool gave me on this tearout prone piece of wood - even with my clumsy never-even-seen-a-hook-tool-before efforts! It's like "no sanding needed!" I did have the beginnings of a catch and the "clutch" performed as it was designed and let the bit swing out of the wood instead of digging in. Once I have experience with it, I may tighten down the clutch more to allow more aggressive cuts.
Re: Cutting
Jorge Castaneda
>Carol, good to know you are making shavings.
With the two edges, one does the outside of the piece the other the inside, the hook is just a gouge in disguise, at 90 degrees so it can get where a gouge cannot, in the outside you go from left to right and on the inside right to left; you are right, a sharp hook leaves a very smooth surface, just keep at it and I suggest tighten it well and do not play with it loose. I also think the apex it is not sharp enough, from what I can see on the picture.
Good luck and have fun
Jorge
Kelton Hook Tool
Greg Jensen
>Here are the basics. As someone posted in a photo you do need to sharpen the tool further around the curve (the red area of the previous photo).
Draw a line from center to 9 o'clock and from center to 7 o'clock. The area between the lines is where the tool should be positioned to cut. Start with the "tail" of the hook pointing strait up at 12 o'clock. This makes the lead cuting edge strait up and down. Rub the back of the "tail" or bevel on the wood. Move the handle to the left to pick up the cut. Then to make the tool cut more agressivly rotate the handle clock wise a degree or two. The more you rotate the handle clockwise the more agressivly it will cut. The hanlde of the tool should be high and the tip low. I normally have the toolrest at center. I tuck the handle of the tool into my right arm pit. The shank of the tool is angled down at approximatly 20 degrees and my cutting tip is below center. Pull the tool toward you while cuting.
If you need to sharpen the inside bevel I use a chainsaw sharpening stone on my Dremel tool.
Greg Jensen
North American rep for Kelton Tools
Call if you have questions cell 440-570-7596 Cleveland Ohio
Re: Kelton Hook Tool
Carole Valentine
>Thanks a bunch Greg! That's about what I have finally figured out. Once I raised my tool rest a bit so I could drop the tool tip down some in relation to the handle, things went much easier. The sharpening part is another matter...I hope I don't screw it up!
Gary Ljostad
>Carole, the Martel hook tool is my favorite tool for hollowing end grain. Check out www.thewoodworkingchannel.com They have a video of Andre Martel using his hook tool. It was filmed at the 2005 AAW symposium. It shows the various cuts that can be made. You will have to check the schedule to see when it is on. From your photos it looks like you are on the right track.
http://thewoodworkingchannel.com
I'm hooked :)
Carole Valentine
>As I said, this piece of wood was dry and almost crumbly. For the fun of it, I sharpened my teardrop scraper and made a pass. You can see the tearout on the left pic. I then made one pass with the hook tool. That result is on the right. That's enough to make me want to master this baby! :)
Thanks everyone!
Carole Valentine
>All your tips have helped. Long ways to go, but I am getting there. I can always count on my WC friends when I am having a problem. The tool was sent to me with the one section intentionally rounded over a bit to reduce it's aggressiveness. I sharpened that as suggested and things were much better.
Wonderful Thread! Thanks.
Barbara Gill, Remlik VA
Brad Vietje
Re: Cutting
Brad Vietje
>Carole,
I read all the comments so far, and I'm glad that Greg from McNaughton confirmed my comments. I hope he can comment on the "other" edge, too... I don't advise you to cut from rim to center, as you guessed, unless Greg says that's the thing to do !
On the Martel tool, this right-side bevel is used to very gently drill a hole for the cuts made with the left-side edge. The cut is not quite the reverse of the "normal" cut, but more of a gentle rocking motion, starting in the neutral (non-cutting) position, and angling the handle just a bit away from you. Like "back-hollowing", you'll be cutting the wood rotating up and toward you, instead of the usual down & away toward the rest, so you'll want to make very gentle cuts. With the Martel, you can create a small hole at center (~1/2" wide and deep), and then use the "normal" pulling cut to remove wood from this center hole to outer rim. There's no need to cut to the intended depth in a single operation -- much better to cut a little bit at a time, as needed, until the ideal depth is reached.
Safe spinning (and great results so far !),
Brad Vietje
Newbury, VT
Cutting with the front edge
Greg Jensen
>As you mentioned it is used to drill a hole.
I also use it for shapes that the rim of the piece hits the shank when using the traditional pull cut. I lower the toolrest then position the tool oposite to the pull cut. Handle is down low and to the right of center about 4 o'clock. Tip is high and above center. Tail of the hook is down at 6 to 7 o'clock. This is a push cut from center out. This cut lets you finish a deep piece,
Greg
Darrell Feltmate
>Carol
I have really enjoyed this thread. One of these days I have to grind a hook out of stainless but until then I like my forged ones. I notice that you are using a standard tool rest in the pics. Try making one of my gates. It will really make a difference especially on hogging cuts and on final shear cuts. I like to start with the rest slightly above center so that the tip angles down to about 7:30 or 8:00 and rotate the tool counterclockwise until it starts cutting. Then just ride the bevel and the gate. If I can help, send an email. I do not check this site often enough.
Around the Woods
