Lathe purchase/ Spindle turning
Orion/.Denton, TX
>I'm needing a second hand lathe to turn chair spindels. I am not a turner and don't need to do anything other than turn chair spindles. Any advice on makes or models? Minimum hp I should look for? I want to be able to use a duplicator with it also. I see lathes on ebay all of the time but I'm worried that I wouldn't be happy with one of the cheap import machines or the lightly powered older machines like the dunlop 101.06242. I really don't want or need a large lathe and would like the smallest size lathe that would do a good job.
Any and all advice is appreciated.
Re: Lathe purchase/ Spindle turning
Re: A used Delta or Jet with .....
Jamie Donaldson
>...long bed and 1 HP would do fine if you can find them. Anything larger won't be necessary unless you catch the turning disease!
>Jamie's dead on. One of the old Delta/Rockwell flatbed lathes would be an excellent choice. They usually come with 1/2 or 3/4 horse. I like at least 3/4 for spindles but 1/2 will do it's just slower. You can get duplicators that fit these. You should be able to get one of these used for $100 to $200.
Jet mini
Bob Fawcett
>A Jet mini with the bed extension will allow you to turn most spindles. I turned a bedpost on mine before I got my Powermatic. I think you can do about 40" between centers with the extension.
Re: Jet mini
Don Henthorn
>I agree the Jet mini would be a good choice and for spindle turning the non VS would be fine.
