One side of the Lathe, or both?
Allen Neighbors
>I read some interesting things in the post about containing shavings and such. Something that really piqued my interest was that many posters said their lathe was next to a wall. I think that would mean they have to do all their turning from one side of the lathe.
I don't think I have ever completed a bowl, vase, or hollowform while turning from only one side of the lathe. Spindles, maybe, but nothing else. So... my question is this:
Do you turn from just one side of the lathe... or from both sides?
Just curious... thanks in advance...
Re: One side of the Lathe, or both?
Norm Smith in Nova Scotia
>Allen , I turn on one side only. However I have a Powermatic with a sliding headstock and turn a lot on the end of my lathe.
Norm
georgetroy
>I don't turn from the right side, it's the front side or the end. All my lathes have the ability to turn outboard by sliding the headstock or swivel. We are talking the Robust,Powermatic,Vicmarc or DVR here. If your controls are on the front that is were you need to be in my opinion. GT
Gary in Zirconia, NC
>Probably about 60% from the front, 5% from the back, and 35% from the end.
Rick Davenport
>Allen,
I occasionally turn on the other side, especially with wood that likes to tear out. I can get a nice clean finish cut/shear by slipping over to the other side of my Powermatic.
And I sure slide my headstock around a lot to get inside my bowls.
I just love my Mustard Monster and can't imagine how I would get by without it.
R
Bob Fawcett
>Allen,
I also have a Powermatic. I turn on one side, or the end. I have never had occasion to want to turn on the other side yet.
Bill Howatt
>I turn from the usual side only. I have a General 26020VD which means the work is relatively high off the bed and I find it fairly easy to lean over when I have to.
Having said that I think it is a good idea to allow access from both sides if possible.
Bill
Stuart Johnson
>I use the backside maybe 10% of the time.
George Balock
Re: One side of the Lathe, or both?--One Side
George Balock
Ric Taylor
Ric Taylor
>I go over to the dark side once in awhile.
Ric
Carole Valentine
>I turn from both sides. Sometimes going to reverse and turning from the backside of the lathe is the only way I can tame a really stubborn piece of wood.
dtewell
>Ric, we're talking about turning, not flat work.
Brian McInturff in SC
>All 4 sides.
Re: Both sides, both ends
Russ Fairfield
>I have a powermatic so I turn from the front and end.
Brent at Robust
>I think the trend you are seeing in this chain is that those of us with sliding headstock lathes take advantage of the feature and turn mostly from the front or from the end. This is much more ergonomically correct and safe, especially if your controls are fixed. Folks with fixed head lathes will turn from the back, because they do what they have to do to get the job done. There is always a bit of danger if you have to reach across rotating work to shut the machine off though. Interesting question. Thanks for asking it.
Re: One side of the Lathe, or both? *LINK*
Darrell Feltmate
>Allen
I turn from the front of the lathe. That said, I also use a bowl lathe that lets me stand in front of the piece and the headstock on one of my other lathes rotates so I can stand in front of the piece as well. Spindles are all done from one side.
Around the Woods
guy
>I turn on both sides and some times from the end. I have a remote on/off switch. I am left handed, so I pick were ever I feel safest. also all left handed people are without sin, when you comit your first sin you turn right handed. This a left handed bishop told me.
Allen Neighbors
>I should have mentioned that I've never turned in Reverse... sanded, but never turned. Maybe I should try that with difficult wood. Thanks for the idea, CV.
Allen Neighbors
>Thanks, everyone! I appreciate the responses. I've learned two things from all this. One, I'm finally going to give it a try in Reverse... I've thought about it, but never have tried it, now I will, when I get the next piece of hard to control wood.
The second thing I've learned is that it must be true that we ambidextrous people are truly blessed... could it be because our sins were little ones? :o)
Be like proud Mary... :o)
Rick in Colgate, Wi
>Just remember that running a lathe in reverse can unthread a chuck or faceplate in a heartbeat!
Dave Peebles Lyons, Ohio!
>But not on my Oneway :)
No shower curtains for me. Lathe is in the center of the shop. Shaving flying, I worry about clean up later. I turn from every angle that will give me the best cut. Not rules in my shop :)
Dave
George Van
>Aaaaand how do you know that Rick?
bob davis
>right, left. end
Since I turn on a Jet mini
Don Henthorn
>I just turn the lathe around. (G)
