Coral Winestoppers
Coral Winestoppers
Coral Winestoppers
Ed Kelle
>Branching out my coral theme to these stoppers now. Made from Maple, textured and colored, they use Ruth's stainless steel stoppers.
Re: Coral Winestoppers
Jim Shaver Oakville, Ont.
>Hi Ed,
A really cool looking design I identify with your name now, I love seeing this evolve. Really cool idea!
take care,
Jim
dtewell
>I don't want you to give away any professional secrets, but how did you do that? Great looking stoppers.
David Galloway
>These look GREAT! They are such a departure from what I do. I hope you will be a "good" woodturner and share your method as suggested above. Then we can all plaguerize. Seriously, I am fascinated by the texture. Very cool.
Coral Winestoppers - Good Stuff!
Ed Moore
>Ed,
Like Jim said, when I see these I know that you did them. They are really nice! I hope that you sell a zillion of them!
Ed Moore
Thanks guys
Ed Kelle
>They were done with my Dremel and lots of patience. I am continuing to explore and refine this technique on different forms.
Re: Thanks guys
George (Oxford, NC)
>I sorta' get the idea using a dremel, but could you give a little more detail? Same bit at different angles of attack or different shaped bits? Dye before or after? Etc, Etc?
Thanks
George
Re: Thanks guys
David Galloway
>I have done a little work in Binh Pho and have some idea of what you are doing with the Dremel. If you have the time, please let us in on how you are doing this. Very intriguing. You should do a workshop at AAW!
info
Ed Kelle
>I shape the piece on the lathe, then rough it out either with the Rotary chisel bit, like a mini router bit, or I use a spiral flute cylinder bit in the Dremel, giving lots of depth to areas. After that I use the round spiral ball bit to carve away the holes. I go over the entire piece a few times until I am happy then do some cleanup of the fibery tearouts it can cause. I work from many angles and directions on the wood. Finishing is thin washes of oil paint. Then let it dry for a few days, scuff sand the high spots for contrast and seal with a few coats of spray workable fixitive.
Have fun
