THE WOODRAT IS BACK!
Wood Dye
Wood Dye
Wood Dye
mark4583
>Ive been trying to find a little info on dyeing some pen blanks.
Is it better to turn near finish form and then die or should I die the Blank first?
What type dye would you recomend and what process?
Thanks
Re: Wood Dye
Re: Wood Dye
>I haven't turned many pens but have dyed a lot of wood. The dye doesn't penetrate very far so it's easy to sand through. I would sand up to about 600 grit and then dye. If you use a water based dye raise the grain by rubbing it with water and then sand very lightly after it's dry to remove the raised grain. I would then apply the dye and then a layer of finish before sanding any further.
Re: Wood Dye
Re: Wood Dye
>I haven't dyed any pens either. Ditto what John said as far as application. When dyeing furniture, I raise the grain with water, sand to 220-300 and repeat. I like Transtint, but there are many other good ones out there.
"Sneak" up on the amount of dye to water. Put a couple of drops in a measured amount of water. Try the solution on some scrap. Go up or down from there. You can "wash" some of the dye off with isopropyl alcohol or ethyl alcohol.
Re: Wood Dye
Re: Wood Dye
Steve Worcester
>The only way to get the depth of penetration for the dye in an unturned blank would be to pressure dye it first. You can put the blanks in a tub of dye then put them in a paint pressure pot for about 24 hours under about 50-60PSI. The problem is you are forcing dye and it's carrier, alcohol or water thought the entire blank again and possibly having to go back through a drying process.
If you dye the turned item, the penetration is low enough it most likely won't affect it's moisture content. Like the others say, sand, dye (let dry), light sand, finish. I would let the dye dry for 24hrs before finishing. Experiment with the type of finish you plan to use so that you figure out if the dye will transfer to the owners fingers.
Steve Worcester
www.turningwood.com
