Elbotool, Jamison, or other?
tek-Brunswick, Ohio
>I'm going to purchase a captured hollowing tool and laser rig soon. I know a while back to elbotool had some fans here. Could I have some input on what you like about your favorite hollowing system? I would like to use my John Jordon Hollowing tools in whatever I get.
Thanks
Tom
Re: Elbotool, Jamison, or other?
malcolm Connor
>Hello Tom, I have the Elbow Tool and like it very much. The Elbow Tool is really a pleasure to use; it almost completely eliminates the torque problem and the tight grip needed on all the other systems. There is no need to be tense while using this system. The operator can stay at ease, which will eliminate all the stress normally associated with deep hollowing. I know in our small club there are at least 6 people that ownes this tool, with everyone loving it. I also have the John Jordan hollowing tools - both sets, large and small, you will need an adaptor for the large set. They work great with the Elbow Tool - hope this helps - thanks Malcolm
David Galloway
>The great thing about the elbotool is that it has adapters for just about any tool you want to plug in. This should be a lesson to those who design tools. I can fit almost all my hollowing tools into the elbo. This is a great system, quick to set up, and use. I recommend it highly.
Brent at Robust
>I tried out the Elbo tool at SWAT in Texas a few months ago, and was really impressed by its quality construction and ease of use. Stan (the inventor) was also demonstrating it using some Jordan tools (don't recall if an adaptor was needed or not..)
If you want to use it with other tools, like the Jamison, suggest dropping Stan an email at staninvent@cox.net and getting his opinion on what will fit or not.
Good Luck ! Brent
eliot d
>I have the Elbo tool and like it a lot. But it has one significant drawback. Because, by design, it attaches to the tail stock quill, you may be somewhat limited in the depth of vessel you can hollow. There's the headstock, the chuck, the vessel, the tool bar, the elbows, and the tail stock. Unless your lathe bed is pretty long, you can see that things get crowded. Stan does sell( for around $80, I think) some kind of extension to overcome this problem to some extent.
When it comes to deep hollowing, I turn to my SpinDoctor rig. It's massively built, and much of the stuff hangs back over and beyond the end of the lathe bed.
Brian McInturff in SC
>I'd have to give my vote to thespindoctor also. I've finally decided on his system with the Steady rest. I just need to figure out what to get rid of to afford the setup. It aint cheap but it beats hand down everything else I've seen or tried.
Bill Hale / Woodspinner
>If you do buy from Stan and have any problrms he will be ther ready and able to help.
When the tool first came out it had a weld problem at the mount and he quickly resolved the problem and provided me with a new unit.
Bill in Casa Grande, AZ.
tek-Brunswick, Ohio
>THanks to all. I'm thinking of going with the Elbo. I don't think I�ll go to really big forms and the spin doctor is a little more money than I want to spend. I see most of you that have one are happy with the Elbo tool
David Galloway
>Like everybody has said "Stan's the man". Can't go wrong. I love a designer who keeps the normal woodturner in mind, i.e. the adaptors for any tool!
Jorge Castaneda
>Malcom and everybody,
Where can I find info about this Elbo tool?
Many thanks
Jorge
Here is the link *LINK*
tek-Brunswick, Ohio
>His website is a work in progress. E-mail Stan and he will send you information and his phone number. I ordered mine today. I should get it in a few days I'll let you know how it works out.
http://www.elbotool.com
Muchas Gracias!!
Jorge Castaneda
>Ted,
It will be good to heasr your thoughts,
Thanks
Jorge
