A little last minute help with cleanup??
David Breth
>A few weeks ago I posted about a cane I intended for my dad. Well, intent has become reality (thanks for the assistance once again - esp. Mike Cunningham for providing step-by directions), but I've got a finish problem.
I'm using Minwax Wipe-On Poly, and have gotten some on the brass fittings. I'm figuring that a Q-tip with a little bit of _______ will do the trick, but I could really use some help figuring out what ______ is. Acetone? Mineral Spirits? I'm sure I could work it out with steel wool, but will score some brass that I'd really rather not score.
Going to bed.....been up wrapping while the little ones sleep.
Thanks -
David B.
Re: A little last minute help with cleanup??
Cyril Griesbach
>If it's still available, Brasso should work with some effort and not mark the brass. I remember using it in the Army on the brass belt buckles that were covered some kind of clear coating when new. An occasional touch up will keep the shine as well.
Cyril
Gary Evans Tallassee, TN
>Hi David,
Acetone is a solvent for polyurethane, but I don't know if it will cut a dried finish. Won't hurt to try it, though.
You might also try some polishing compound. Might take a while to work through the poly, but at least you wouldn't have to worry about scratching the brass.
Good luck,
Gary
tek-Brunswick, Ohio
>Brass is usually covered with a clear lacquer to help keep it from tarnishing, (oxidizing?) after removing the poly I would mask off the wood and respray the brass with a clear gloss lacquer. One of the mail-order houses carries a lacquer for brass, but I don't remember which one, any lacquer would be better than none.
>I just made about nine canes for a customer. Seven of them were jointed with the brass screw toghter fittings. Customer wanted Watco on the walnut fo the canes. By the time it was over I think I used a whole role of tape masking and remasking. The fittings had lacquer. I used epoxy to reinforce the connections fo the parts of the danes to the wood. So, at various times I had epoxy on the brass, Watco Danish oil on the brass, and lacquer on the wood. In spite of taping.
I found that my Beall Buffing system woudl do a good job removing stuff from the brass, leaning it polished beter than new, but then I had to replace the Lacquer. I used the white diamond wheel. The brass turned black immediately and I alsmost panicked, but found you can wipe the black off with a paper towel. It also turn thebuffing wheel black, but I cleaned that with some coarse sandpaper.
It was a PITA trying to keep "this" off "that". Even with the tape some of it crept under the edges. I tried buffing with the tape in place and the heat cause the tape to REALLY stick. I was finding that buffing is imprecise and if you buffed the brass you also buffed the wood beside it, but the customer wanted a low gloss "in the wood" flat finish on the wood. In one case I tried taping the brass fitting, letting the tape extend over the edge a bit and then filing it of with a shape file. The file cut the tape perfectly to the edge of the brass. I scewed the head on the cane and there was a little epoxy squeeze-out. The epoxy glued the EDGE of the tape to the cane. Took a while to remove the tiny blue ring.
Re: I would leave the poly on..
Jamie Donaldson
>... the brass to reduce oxidation if it's not too obvious.
David Breth
>I wish I could leave it on, but it is pretty blotchy.
I'll try some acetone with it. Will also try some fingernail with it. Best option may well be polishing compound, unfortunately, that will strip the laquer right off it, and really, once off, I'm not going to risk reapplication - who knows what I'll do to the wood if I try that, even with judicious taping.
Thanks very much for the tips. This isn't a fatal flaw really, and I'm sure I can do something about it, but I sure would have rather not deal with it.....
David B.
