REAL MILK PAINT
Contain chips and shavings
Dinyar Chavda
>I am curious as to how people position their lathes (relative to walls) so as to contain their chips and shavings as much as possible. Do you place your lathe with your back to the wall, facing the wall? Or do you place a curtain around the lathe? If so, does it go all the way around the lathe?
TIA.
Re: Contain chips and shavings
Norm Smith in Nova Scotia
>Dinyar, I use clear plastic shower curtains around my lathe. They work great and are cheap at Wallmart
Norm
Stuart Johnson
>I don't have my lathe against a wall which is good because I will walk around and work from the backside. There is a mess with shavings all over the place and from time to time (once a month) I have to stop and clean. One day I'll try and rearrange the shop but that is pretty far down on my list.
Cyril Griesbach
>I'm facing the wall when I'm turning and the shavings go where they wish. Usually my wife comes in after work and cleans up the shop. Our neighbors burn the shavings in their wood stove.
Lucky me, lucky me, lucky me.
Cyril
Terry Quiram, Roanoke Illinois
>My lathe is in a corner. I turn with my back/left side to the corner. I hung a shower curtain around my lathe to control the noodles. I am not lucky enough to have a clean up assistant so I shovel them out to the garden and compost pile.
Dave Belser
>My lathe is firmly bolted to a raised concrete slab with a wall behind it. I have a rotating headstock that I use occasionally when I need better access. When I'm roughing, I'll arrange my various tool boxes and a rolling artists cart that stores smaller stuff around my lathe with the tool box covers open and the drawers of the cart pulled out. I've found this a particularly effective way to collect the chips and it also has the benefit of forcing me to clean out the tool boxes and cart :)
Seriously, I've thought of hanging a leftover fake bamboo porch screen behind me to protect the table that I work from but haven't gotten around to it. I've found that I pay a lot more attention to the task I'm about to perform and remember to setup for it. This means picking up and closing up before roughing.
I can't tell you how many times I've done the tool box trick above, but now it only happens if I've gotten really excited about trying something new and forget to look around and close up first.
- Dave
Bill Howatt
>After spending hours picking shavings out of tools on pegboards, and everywhere else within a 10' or more radius, I build a narrow room about 8'x6.5' for the lathe. Basic rule was to not mount things on the wall for shaving to catch on. Lathe is against the wall.
Works fairly well, I shovel the shavings and have given up on getting the last little bit of them since that takes most of the effort.
Idea of minimizing what is in the room didn't work quite as well as hoped, too many "turning accessories" to store. If you put your lathe near a wall keep it out as far as possible so you have plenty of room to swing long-handled tools.
Bill
George Van
>Dinyar, I hung a pine 1�x1�x10� from the ceiling on wire to which I had attached a 10�x10� piece of poly (ceiling is 11�). The 10�x10� poly is made up of 4 overlapping 3� pieces, it is heavy mil and I staple a piece of 1�x1� to the bottom of the pieces to keep them taught. This allows me to reach through the curtain to reach items that are hung on the wall without the chips going through. I have one between the lathe and the wall and one opposite to contain the chips and more importantly keep the water spray off the other tools in the shop and the wall. I leave the ends open for good access to storage and the grinders.
Bill Crommett
>I'm like Stuart, with shavings all over the place and on top of the car, too. I have to carefuly blow the shavings out of the air intake on the car or they will plug up the ventilation system big time. No neatniks at this house !
>Mine's set at 90* to the wall and I use a poly-e ceiling-to-floor curtian on the right and behind. Bulk of shavings are shoveled into lawn bag. Balance go through the DC
Stuart Johnson
>One lesson about neatness that I learned the hard way. Don't open the garage door and blow all the dust and odds and ends out if the truck parked in front of the door is still wet from a heavy dew. This is especially important to remember if your spouse needs it to pick up a friend and go shopping.
Bob Fawcett
>My lathe sits in a narrow "room" formed by a corner of the shop and a stud wall I had to add after the HVAC contractor cut large holes in the I-joists. The stud wall is behind the lathe. I stapled clear poly to it to block chips, but let light through. The poly stops about a foot from the ceiling to allow air through. I have another poly curtain that hangs from the ceiling 3 or 4 feet behind me when I stand at the lathe. This is on a rollup arangemnet similar to a bamboo curtain. There is a 1x1 scrap the length of the curtain that it rolls around attached to the bottom of the poly with staples. The rollup is made with mason's string simply loops around the curtain.
When I rough a bowl, I can sit a cardboard box on the floor at the foot of one of the curtains and if placed correctly, most of the curlys land in the box. Hitting the box has almost become a game on roughing days!
>I have not even attempted to put dust pick up or containment curtains on the lathe. I am reading this with interest, becasue I would like to. However, when sanding, I bring the hose up from the DC and usually hook it under the tool rest and position it close to the work. Then I play the "wind tunnel" game to see if I can cause the stream of sanding dust to flow through the air into the DC hose.
I got to get me one of those boxes.
Bob Fawcett
>Here is a picture.
You can see my rollup curtain on the left. The box of shavings is in the corner at the moment but may need to move closer to the viewer to catch them.
keith zimmerman, Normal IL
>As I turn in a walk-in closet, I stand facing the back wall with the lathe at an angle so I can stand at the end when I am hollowing. I have to close the bathroom door behind me to keep everything out of there.
A shopvac is used to remove chips and shavings.
