turning pencils
Bob Fawcett
>Seems like I saw an article on making a turned pencil using the guts from a Pentel pencil. Anyone know where that might have been??
Thanks
turning pencils
Bob Fawcett
Thanks
Re: turning pencils
eaglesc
>Check the home page of the IAP.
IIRC CSUSA sold a step bit that was ridiculously priced.
Someone came up with a way to do it without one.
Take a Pentel apart and a little measuring will have the answer.
Re: turning pencils
Bob Fawcett
>Thanks,
I found it. Its at Nick Cook's site if anyone is interested.
You can buy a step drill, but with a little care in drilling you can do it with 2 or 3 bits. I marked the center of my wood, drilled on end with 5/32" and the other with 17/64". You need about 1/2" depth with the 5/32" and about 1" with the 17/64". Then take a long 1/4" bit and drill from the big end until the holes meet. Take the mechanism out of the pencil and test fit. You need the 5/32 side to be about 1/8" or maybe a little more. My wood is the same length as the plastic of the original pencil about 4 7/16". My 1/4" bit is chucked so that the bit extends only 4 5/16" from the chuck. This way when the bit grabs the wood while drilling the last bit, it won't come through the end. I'm not really this clever, I learned this by almost drilling through. Dumb luck saved me.
Re: turning pencils
TDRice
>You can buy a step drill to do this - DON'T. The one I bought was worthless. I made my own by grinding down a 1/4" spade bit. Buy a pentel,split it down the center (lengthwise)and use the measurements to grind your step bit. I found by far the best price for pentel at www.discountofficesupplies.com.
