Bodan? / Badan?
Bodan? / Badan?
Bodan? / Badan?
RobV
>I was watching the Woodturing Workshop the other day on PBS and he used a tool called a "bodan" (sounds like that, I may have the spelling wrong) to rough out spindle turnings... I was wondering what are the dimensions of a bodan tool? ie. angle of grind, width, etc.
TIA
Re: Bodan? / Badan?
Re: Bodan? / Badan? *LINK*
AndiWolfe
>The tool is a bedan. It comes in a variety of widths. The one I like the most is the 10 mm one. The top width is slightly wider than the bottom of the tool (shaped like a trapezoid in cross section).
Jean-Francois Escoulen has introduced this versatile tool to us here in the states. You can see some detailed pics on it's use from my July 2006 archive where I posted six days worth of images and description from his visit to us at the Central Ohio Woodturners.
Here are the relevant days' posts:
http://andiwolfe.blogspot.com/2006/07/jean-franois-escoulen-visits-central.html
http://andiwolfe.blogspot.com/2006/07/jean-franois-escoulen-class-day-1.html
http://andiwolfe.blogspot.com/2006/07/jean-franois-escoulen-class-day-2.html
http://andiwolfe.blogspot.com/2006/07/jean-franois-escoulen-class-day-3_15.html
http://andiwolfe.blogspot.com/2006/07/jean-franois-escoulen-class-day-4.html
http://andiwolfe.blogspot.com/2006/07/jean-franois-escoulen-class-day-5.html
July Archive of Andi Wolfe's blog
Re: Bodan? / Badan?
Re: Bodan? / Badan?
Sean Troy
>I use the Bedan tool from fine scraping to forming a dovetail.It's a great little tool. I have two, one with a straight across grind and one with an angled grind.
Re: Bodan? / Badan?
Bedan!
RobV
>Thanks for the info... it seems to have about the same dimensions as a 3/8" wood chisel... maybe just a little less angle on the edge.
Re: Bodan? / Badan?
Sharpening?
Ron McKinley
>Hi Sean: What's the best way to sharpen the bedan? I've just been using a diamond file to touch up the top and bevel. Should I grind the bevel like a scraper? Thanks......Ron
Re: Bodan? / Badan?
Re: Bodan? / Badan?
TDRice
>Stuart Batty taught me to use the bedan to do the final turning on the bottom of flat bottom pieces. If properly sharpened it leaves a very nice surface.
Re: Bodan? / Badan?
Re: Sharpening?
Vincent Welch
>Hey Ron,
I understand the best way to sharpen Bedans is with a diamond honing file and it sounds like you are already there. Vince
Re: Bodan? / Badan?
Re: Sharpening?
Sean Troy
>I just use the grinding wheel and wolverine jig. I put the base of the handle in the V holder and can slightly turn and hold the Bedan as I sharpen lightly at the angle I like.
