Re: Chunkin' with the SKEW chisel
Greg Haugen
>Ricco, if you're in WI, MN, IA I would be glad to work with you. Everyone's posts were good. But you're saying you have a chunk missing, not out right saying the nasty word of "catch." If you go the wrong way with some woods (like petting a dog from the tail to the head) you'll get a tear out or chunk out also. Just like a board going through a planer, one way is clean the other way isn't. If you're not catching to get the chunk out and you're using a planing cut go at from the other way. Figured Maples are a pain for this. If you're rolling a bead and catching usually its because the handle is moving too much and the bevel is lifting creating that "skate" effect. Also you can roll a bead with the heel of the skew in the wood. This in theory helps to hold the bevel against the wood. Not a catch proof technique at all though. You can also just use the lower third, nice cut but more of a "advanced" cut. If you're having a real catch, the tip is getting pulled in. The area that is cutting is too high on the skew. Stay in the lower third of the skew. Even if your starting there a tenth of a second before it catches its moving too high and pulling it in. Also try and use a forgiving center to drive, either a dead cup center like Oneway's or Delta has one too or a Stebcenter from Sorby. Both will minimize damage if it occurs, or just stop the rotation of the piece.
As far as what skew, I have alot of them. Lacer/Raffan's has good points and bad points, The straight also has good and the bad. What I say is learn on one, and never let it go. If you can use the skew your in a group about 10% to 15% of of all turners. I have both because I really like to teach the skew as much as use it. I do live in WI and have spent time with Alan at his house on the skew and I'm also headed to Appalachian Center for Craft in July for a week with Nick Cook. Being with these guys you always take something a way with you.
One last thing, SHARP SHARP SHARP SHARP SHARP!!!! Don't matter if you use a diamond hone, oil stone, Tormek, or your neighbor's dog hide-just kidding. Off of a dry grinder isn't sharp enough for the skew.
If there is anything at all I can do let me know.
Greg Haugen
