Lumber? for a turned leg
Alan Young
Alan Young
>Dear Round Work people,
I hardly ever venture to this side but I have a project coming up that will require a bit of lathe work.
I will be building a desk with turned legs. The stock required is 3" square/diamter... The profile will look like this.
The wood will be cherry. I am wondering about the +'s and -'s of making these legs from solid 3" stock or laminating stock to that thickness.
The laminations will have a glue line and even though I'll likely be be applying a stain to even the color I suspect the line may show. My question about the solid 3"+ stock is what do I need to look out for in turning something this thick? Will it check and crack? That would be worse than a glue line. How do I avoid such problems or any related
issues? I am posting this on the main message forum also.
Thanks
Alan
Re: Lumber? for a turned leg
Jim Shaver Oakville, Ont.
>Hi Alan,
Wow, 3x3 is a heavy leg.
The only thing I can contribute is to pay attention to grain in the blank before you select the wood. For turned legs I always try to get wood that has the end grain alignment from corner to corner,diagonally across the blank. It shows as vertical grain on all faces of the leg, grain that runs across the end grain face to face shows the flat grain alternating with edge grain on the leg, not as attractive.
Hope that helps.
take care,
Jim
Bob Fawcett
>I built some bedposts recently and they are about the size you specify. In my case the only choice I had was to laminate. I did have 8/4 stock so my pieces are only 2 laminations. The legs are currently sanded, but not finished yet. The glue lines are barely noticeable at this point. I do plan to orient the posts so the lines are out of sight from the most frequently viewed angle.
I am sure applying finish will highlight the glue line somewhat. In this case the lumber is Sapele not Cherry.
One other thing I did. The boards were 6+" so I ripped them in half and made each blank from the same board. This allows the grain to match on the laminated sides and helps hide the glue line.
Bill Grumbine (Kutztown PA)
>Alan, check Woodfinder. There are some places here in PA that stock 12/4 cherry for legs. That is the route I would go, and have gone in the past. I have turned laminated legs for customers as well, and they are no fun at all. One guy brought me some laminated hickory (five boards in all!) that was bone dry, hard, stringy, and had several snipes per board, leaving voids in the interior. Solid wood is a lot more fun to turn.
Bill
David Walser
>Alan,
You've been given some good advice so far. Now's my chance to lower the average! To respond to your concern about checking and cracks from solid lumber, that should not be a problem as long as the stock you are using is dry and does not include the pith. If you are cutting your own stock from cherry logs, that might be a problem -- it can take a long time for 12/4 planks to air dry! If you are buying from a lumber yard, it should not be a problem at all. Just make sure you check the moisture with a reliable moisture meter before you buy.
Where ? Oh, Where?
Ron Bauman
>The are a couple of mills hereabouts (SE Wisconsin) that offer what is known as "mantles", ie. the stock is up to 16/4 or a bit more. It's used for fireplace mantles, I should think you could cull enough out of this kind of thing for your desk. I believe the stock is kiln dried, but best to use a meter.
Alan Young
The search is on.....
Alan Young
>for 12/4. Thanks everybody for your thoughts. If my only choice were to be a lamination-I could make it work-maybe fluting the leg would distract the eye from the glue joint....
But I am pursuing sources for the solid stock.
Pics coming in a couple of months.....
Alan
Re: The search is on.....
John Morovich
>Alan,
I recently turned some solid 2" cherry stock with no problem, which I ordered from Rockler . They also list solid 3" stock at 18 and 30" lengths.The few times I have ordered thru them the square stock was clear and free of any checking.
