? about pen finishing
Scott Hurley in N. VA
>I've looked in the archives and the articles, and haven't found an answer to my question. Will wipe-on poly be a strong enough finish for pens? I know that a friction polish will wear down over time, but I have some clear wipe-on poly available and wonder if that will hold up.
Thanks.
Scott
Re: ? about pen finishing
I use it
Tony - Memphis
>I have used it on many lathe items for a stronger finish than the friction type. So far, so good.
Tony
Scott Greaves in Blackfoot Idaho
>Hi Scott,
I think it should work just fine! I would imagine it is a slow finish, though. In this fast-paced world, I am used to turning a pen in maybe fifteen or twenty minutes, and applying the finish in about five minutes, with the ability to assemble the pen and be done with it shortly thereafter. I don't believe you can do that with the wipe-on poly - hence the "slow" description. If you have the time and the patience, I believe the poly would be a nice finish!
Scott.
>Thanks for the quick replies.
Scott
