Best finishing tool for inside bowl?
Tom Libby
>Goin shoppin at Woodcraft for Tom's Chistmas present with some of my bonus bread. Right now I'm thinking a Sorby extra heavy duty 1 inch bowl scraper and sanding discs for bowl inside finishing. Opinions, please?
Re: Best finishing tool for inside bowl?
Gary in Zirconia, NC
>Good choices. I also like a 1/2 inch bowl gouge that I grind with a traditional grind at about 60 deg.
>Tom I bought one of the Henry Taylor heavy duty bowl gouges. It really is nice but unfortunately it's still a scraper and leaves minor tearout although a lot less than my small one. I spent some serious practice time with a sharper bowl gouge (I have one at 40 degrees and one at 50 degrees) Now I almost never use the scraper on the inside of bowls. Now I use the scraper mostly for flatening platters.
I won't tell you not to buy one because I did really enjoy it when I first got it. It's just not the cure all. It's better than sandpaper for getting out larger tool marks because sandpaper tends to leave lumps. If you use it as a shear scraper it's pretty good for getting out some tear out but good technique with a sharp angle bowl gouge or even a spindle gouge like Keith teaches is better.
Rick Allen
>I find the best tool for improving the surface on the inside of a bowl to be upgrading the tool between your ears.
Find a local woodturner who's work you admire and get him (or her) to give you a lesson on finishing cuts for bowls.
Greg Haugen
>A scraper isn't a bad thing. But there are better ways to turn the inside of the bowl. I like Mike Mahoney's grind which has somewhat been stated already. A traditional shape grind of 60 degrees but having the bevel shortened to about a shy 1/8" inch. That way the "heel" of the bevel doesn't bruise or mar the wood. This is the way I turn bowls and sanding time is cut at least in half. If you have any questions or concerns on the grind contact Mike, www.bowlmakerinc.com
A scraper isn't a bad thing, for those that "time is money" there is a better way.
Another item that I like using is a 3/8" (1/2" actual size) bowl gouge. I think far too often people get narrow minded with one bowl gouge. Having a smaller gouge is very nice.
Hope it helps,
Greg Haugen
Bob Fawcett
>Can you post a picture of the grind you describe, or maybe detail how you create it.
I can't quite picture it.
"A traditional shape grind of 60 degrees but having the bevel shortened to about a shy 1/8" inch. "
Reading this I would think the bevel length is governed by the thickness of the steel in the wall of the gouge.
>Bob I don't grind my bevels as short as mentioned above. After I sharpen my gouge using the wolverine jig I simply free hand a grind on the bottom shoulder to round it over. It doesn't take much to get rid of the bruising problem. The bruising problem is usually there because the bottom of the bevel is sharp. Knocking off this sharp edge is all it takes.
I do grind away much more of the bevel on my spindle gouges but this is mostly because I hand grind these and it simply takes less time when thiers less bevel to sharpen. I also grind away some of the metal to give this tool more clearance for reaching into tight places.
Greg Haugen
>Here is the picture of my gouge grind for the interior of bowls. I have 1/2" and a 3/8" with this grind. What John Lucas said is also my understanding. You can soften the heel of the grind or knock it off and shorten it so it doesn't damage anything. I freehand this grind and just raise the tool on the grinder to knock down the bevel. I run this gouge with the flute at 2-3 o'clock for mass removal and then turn the flute up to about 12:30. Just to get a real clean shearing cut, not a scrape, but still watching that top corner so it doesn't catch. This is a clean and smooth cutting gouge. No torn grain.
Hope that helps,
Greg
TEK
>For realy nasty grain I like a shear scraper with either a round or teardrop shaped blade. (Sorby MultiTip Tool I believe) I've also tried a shear scraper made out of an old spindle gouge. Sharpened so the convex not the concave side of the gouge is up, and used in scraping mode not cutting mode. Both methods can improve the surface of the wood. Remember to take light cuts for the finish. Hogging off large amounts of wood and getting a good finish don't usually go together.
GaryG in MD
>Trent Bosch uses a very blunt-nosed (65-70 degree) bowl gouge with almost no grinding back of the wings. He grinds the nose asymetrically -- the right side for the outside of the bowl and the left side for the inside of the bowl. The difference is obvious but small. The right side has virtually NO fingernail -- it looks a lot like what you used to get in a newly-purchased (not ground, straight across the front) bowl gouge. The left side is rounded back just a tad so it won't catch on the inside curve. He uses it on-bevel with a VERY light touch to just skim the surface. This gives a shearing cut which is superior to any kind of scraping. ...Gary
Re: Best finishing tool for inside bowl? *LINK*
joaz
>You might try my shear scraper. I get a lot of positive feed back on this tool and I have been using it successfully for years.
Instruction's on my web site.
http://www.maine-web.com/woodturning
Bob Fawcett
>Thanks Greg and John.
Duh! Of course you just knock off the unwanted part of the bevel. I have a bowl gouge with the continental style grind for interiors. I guess I'll try releiving that bevel next time I use it.
