You want to hear about cracking?
eliot d
>Someone suggested that I soak a bowl that has cracks in water and then, after the cracks swell closed, use the supper glue. I tried it, and the cracks did close up. BUT... after the vessel dried out again, it REALLY developed cracks -- much larger ones all over the place! That's the way it goes sometimes, I guess. I just put in back it the water bath to see if the cracks swell shut again. Perhaps I didn't do a good enough glue job the first time. Now that I think about it, there must be a lot of stress, so it shouldn't be too surprising if it cracks again. Perhaps the trick, after it soaks, is to put it in a paper bag and let it dry out slowly this time.
Any thoughts?
Re: You want to hear about cracking?
Brad Vietje
Hope you don't need this for Christmas !
Brad Vietje
>The bad news is that the cracks are there, and unless you can make them a design feature, they'll be there for good. Gluing them might keep them from opening up, but they'll almost always show.
I have heard of people soaking a bowl in a 50/50 mix of white PVA glue (Elmers) and water, which does the swelling and gluing in one step. However, you may have a piece with some pretty powerful hydraulics, and you may not be able to keep those cracks closed when it dries.
If it comes out really bad, maybe you could shorch/char it with a torch, and make it an art piece ?
Safe spinning,
Brad Vietje
Newbury, VT
Re: Hope you don't need this for Christmas !
Bill Crommett
>Glue in a wedge of contrasting color.
Pete LaBelle
>Would think soaking a bowl in water to swell it would constitute going thru the same drying process as a green bowl. The same problems would be present during the drying and contracting in either state of "wetness".
My 3 cents worth (adjusted for inflation)
eliot d
>Right; I more or less figured this out. I re-soaked it, and sure enough, it swelled up so you can't find the cracks. But this time, figuring just what you said, I wrapped it up in paper the way I do a freshly turned green vessel. We'll have to see if it cracks again.
Something I didn't bother to say in my first post is that when I soaked it the first time, believe it or not , I added a fair amount of household bleach to the water. I did that because I thought the surface of the wood looked busy and ugly and I hoped that bleach would lighten everything. What happened is that it got DARKER -- but it did get much more uniform in color. I actually like the vessel now. (If it doesn't crack.)
(If I had more sense, I probably should drop this one and spend my time on something more promising. Oh well.)
