We value your privacy.
>does anyone have problems with their work mounted on a faceplate if they remove the faceplate from the lathe and then reinstall it that the work (bowl)is not aligned any more.what could be the problem?any help or advise sure would help.
I use a wide verity of face plates and have encountered this problem with the cheaper colored
aluminum ones which have a narrow shoulder. The oneways and bestwood tools seem to be the best and both have at least a 1/4" shoulder and tighter fitting threads. You can minimize run out by trying a nylon washer that fits your spindle from packard or your local hardware stores plumbing department. You can also try a heavy glob of wax on the threads if your plates are lose fitting.
>Put a mark on the fadceplate and be certain you realign the bowl with the holes from the origianl mounting. Also sometimes the screws will pull the wood up and you'll have to knock the little bumps off to realign the faceplate with the bowl holes
>Are you leaving the wood on the faceplate? If you are then the faceplate may not be seating against the face of the drive spindle. If you have dirt on the faceplate or drive spindle it won't seat properly and can cause this.
Nylon washers shouldn't help this unless your faceplate isn't seating against the headstock.
The wood may be moving. If you are removing it from the machine I assume your letting it sit for a while. When you are removing wood you release stresses in the wood and it will move. This will cause the wood to go out of round slightly and may resemble not being aligned properly.
>It has been said already, the faceplate must seat against the spindle shoulder. Try the faceplate on the lathe by itself... does it seat against the shoulder... are the spindle threads to long for the plate.
