Woodburning Pens - opinions please.
Steve Worcester
>I have an excalibur woodburner (Detail Master) and need some pens that are a ball on the end. Custom is not out of the question.
I have tried the Razertip pens (not the HD version) and they tend to be real hot and eventually melt all the plastic at the end.
I am looking for some fixed tip pens (better transfer of heat) that I can use with my existing system.
Any suggestions?
Steve Worcester
www.turningwood.com
Re: Woodburning Pens - opinions please.
Re: Woodburning Pens - opinions please. *LINK*
>Steve I'm still learning to use the ball end pens from Optima. I'm really starting to like them. They work really well with very light pressure making a nice clean line. A little too much heat and too much pressure and you get a dotted line. It also makes a very good nice round dot with a little more heat. There definitely is a learning curve but I think these are nice.
http://www.carvertools.com/aboutpjl.htm
Bob Elliott
>Steve,
I'm confused. Razertip does make fixed tip pens with a ball on the end. Was yours a replaceable tip type?
Steve Worcester
>At that link he sells them in heavy duty only. The ones I have are not the heavy duty (they are thinner and vented) and melt at the tip. I use them to make a half circle "crater" if you will.
Steve Worcester
www.turningwood.com
Steve Worcester
>Mine was not a replaceable tip. Although, when the front of the pen melts, I cut them off and use them in a replaceable tip.
Steve Worcester
www.turningwood.com
Steve Worcester
>-Nice guy, called and ordered a few pens today - thanks
Steve Worcester
www.turningwood.com
