Re: Upgraded to VS -warning long reply *LINK*
Bruce Wiseman
>I looked at mounting mine on the lathe stand under the head stock side in a small plastic box, but I worried about heat build up. In the end I mounted it on the wall right above and behind the headstock. I made a small control box with the on/off, speed control, etc and glued a couple of rare earth mags on that so that I can place it any where on the lathe that I want. I got all the parts from radio shack and it cost around $20 - $30 to make.
As for speed I mostly run with the belt in the 1440 position. scribe a circle around he center point of your speed pot. Mark the low end or max counter clockwise position. Turn the pot up until the HZ display reads 10, mark that and do the same for 20, 30, etc. When you have that 10 will be approx 260 rpm, 20 = 523, 30 = 788, 40 = 1050, 50 = 1320, and 60 = 1580. But I mostly go by feel and never worry about the rpm number.
All this comes from an excellent web site by a very helpful guy named Ken. Follow the link to turning and then look for the upgrade Nova 3000 it will take you through the whole thing.
http://www.theturnersshop.com/
