Stihl chainsaw problem, & solution
Ken Grunke from SW WI
>I'm not sure if this applies to other Stihl models or not, but my little Mini Boss, which had just gone beyond a year's use, started running poorly and there was some kind of fluid oozing out from the muffler. This was in the hands of a friend I had loaned the saw to, who isn't too keen on things mechanical. I had notions of him doing something he shouldn't have done, like add straight gas to the tank, or some other awful thing. It still started right up and ran, but seemed to have a bit of an extra rattle, like a worn connecting rod or something and had no power.
I asked my friend to take it in to the dealer, as I didn't have time and he offered to pay the expenses if the saw was repairable. He comes back to me saying the service guy knew right away what was up, without even looking at the saw. He sent my friend right back out the door with the solution and when I heard it, I was kind of skeptical because of the internal noise, I thought the saw was a gonner. The fix was just too easy to be true, and I let it sit for a week before finally getting to it today.
Clean the muffler screen, behind the little louvered plate. Burn the gunk off with a torch--I used a kitchen burner. Get it red hot, so the gunk turns to ash and can be blown away.
The saw now runs like a champ again, and I'm so happy to have one less thing to worry about!
Hopefully I can save one person from an unnecessary trip with this message.
Re: Stihl chainsaw problem, & solution
Bill Hale / Woodspinner
>Check your gas oil mix. To much oil will do exactly what you had. It does not all burn and runs out the muffler.
Your local dealer should be able to tell you what mix to run.
Bill in Casa Grande, AZ.
George Van
>Good tip Ken. My little 021 is 16 years old with a lot of use and I have never removed the exhaust plate. Maybe that is why it is getting tired. I will add this to the "thing to do" list.
Greg Jensen
>I have had the same problem. Old gas oil mix does it every time. Mixed fuel is only good for a short time. My dealer switched me off the stihl mix to a synthetic mix that comes in a plastic squeeze tube (forgot name). Have not had the trouble since using this fuel additive.
Bart Castleberry
>A little extra oil never hurt things IMO either. I run a bit heavy on the oil, and have to clean that screen too. Small price for the extensive use i've gotten out of the saw. Air cooled engines are so easy to burn up when running them all day. They also expand and contract so much and more often than liquid cooled engines that are run for longer periods of time at stable temps.
Not trying to second guess thier engineers, but they also have to sell new saws and meet air quality along with longevity of the engine.
I am sure someone will have a reason why more oil will hurt something, so you mileage may vary...
Keith Tompkins
Keith Tompkins
>HI Bill, Stihl recommends 50:1 ratio on all their saws ,even the old ones, according to my dealer. I was a bit skeptical, but he assured me that was correct. I still remember 16:1!
Improper jet setting will do the same thing, no matter the mix ratio. If you cannot set the mixture settings yourself, it's back to the dealer. Too rich causes the condition above, too lean...new saw.
Leo Van Der Loo
It's a typical 2 stroke engine problem
Leo Van Der Loo
>The oil mixed into the fuel is for lubrication, and not all is burned up by the combustion process, you'll see it in the telltale blue smoke that any 2 stroke emits, some more than others, depending on the mix ratio and also the temperature that the engine runs at.
The spark arresting screen that the saws now have will build up quicker if we use more oil in the mix and also if we run the saw for short periods of time, my small PoulanPro that I use around the house has no screen anymore, it was the first thing I did, because I do know the problem these screens are, in the bush they do prevent bushfire and are mandatory.
Short anecdote about the this 2 stroke problem, An elderly man in town owned a 3=6 DKW, (small car with 3 cylinder 2 stroke engine) and every year he would bring his car in to have the sluggish car looked after, the mechanic would take the car out to the no speed limit High Way, floored the pedal and drove the car for a 2 hour trip and the car was set for another year, by driving the car very cautiously the whole exhaust system was plugged up, and driving it at high speed for a prolonged time would burn all the deposits out.
Have fun and take care
Leo Van Der Loo
Jim DeLaney, Austintown, Ohio
>Actually, adding extra oil isn't a good thing.
If you add too much, it will lower the viscosity of the mix (make it thicker). Less of this thicker liquid will pass through the carb's jets than a thinner mixture would.
This actually means that, with the same amount of air, but less fuel, the engine is running lean. A lean mixture will burn hotter, and can eventually lead to a seizure, or a holed piston.
Use the manufacturer's recommended mix. After all, they're supposed to know what's best for their engines...
Jim D.
Mix ratio
Brian Hahn in SW Wisconsin
>My 20-year old Stihl recommends a 32:1 mix and definitely doesn't like a 50:1 mix. It is somewhat of a nuisance because my other saw uses 50:1 and doesn't like 32:1.
Premium gas
JohnD
>You will get better performance and the saw will run cooler if you use premium gas.
Re: Premium gas
Bill Crommett
>Remembner that premium gas is more stable than 87 octane which is made with "dirty" tech. I have used premium gas in all my outdoor machinery for twenty years and I only use Stabil if there is to be a prolonged lay up like in the garden tiller. More octane = less varnish ! !
Keith Tompkins
Re: Mix ratio
Keith Tompkins
>Brian, my saw is the same vintage....if you adjust the carb, it will run great on 50:1. If interested, e-mail me, and I'll give you fairly simple instructions. Emissions will be lower, and I'm told, no adverse effects on longevity.
Re: My new Stihl needs 89 octane per owner manual.
Al Crandall (N.E. of Indy)
Chainsaws and Fuel
Kevin Gerstenecker
>Talk to any Stihl Engineer, and they will advise you to use the exact ratio they suggest. I have owned and used Stihl Chainsaws for over 20 years, and I have been through all the "problems" at least once. With the "reformulation" process of today's Gasoline, the fuel mixture will go bad much quicker than years past. Stihl will tell you that Gasoline starts to degrade after about 6 weeks or so, and saws run best on fairly fresh fuel. It is easiest to mix your 2 cycle mix in smaller quantities so it doesn't get stored for extended periods of time. (Unless I plan on doing a lot of cutting, I mix a gallon at a time. Sure, it means a few more trips to the gas station, but fresh fuel lessens the likelyhood of problems.) The spark arrestor screen can be removed. Unless you cut on state or federal land where a spark arrestor is required, remove it. I have been removing mine for years, and have yet to have a spark exit the muffler and cause a fire. (To be safe, you can leave it place, just make sure you clean it often. A small wire brush does the job just fine.) The newer saws also don't have a high and low speed adjustment screw like the older saws did. (The first thing I did with my new 026 Pro model was replace the Carburetor with one that does have full adjustment capability. It makes the saw run SO much better when you can fully adjust the mixture.) Of course, using Chainsaws professionally for a few years made me a bit more demanding of the performace the saw is capable of.
Also, if you can find Gasoline in your area that doesn't have any ethanol content, that is better to use in the saw. Around these parts, the chain of Casey's General Store sells gasoline with no ethanol additives. I'm not sure why this is better, but that is what Stihl has recommended to me. (It may have something to do with the longevity of the fuel mixture, or perhaps it is cooler burning?)
>Thanks for all the very helpful replies, I now have a much better idea on how to prevent the problem and optimize the running of my saw.
1.) Remove screen, it's not crucial to operation
2.) Use premium gas, without ethanol if possible
3.) Make sure gas is less than 6 months old
4.) Use a 50:1 mix -- I think mine was 40:1, couldn't find the manual so I made a guess.
5.) Don't let the saw sit unused all summer! Find some wood to cut somewhere, at least once a month (not a problem in my area).
Kevin Gerstenecker
>That's pretty much it Ken! A few more things to consider: Stihl saws like Stihl 2 cycle oil MUCH better than other brands. DAMHIKT, but I do. Also, Chainsaws REALLY like to run, often. Cutting often is a good idea you have. Another thing that won't hurt a bit is to add some fuel stabilizer to your fuel. This is cheap insurance in case you have some fuel mix around a bit longer than normal. Other than that, you have it my friend! Good luck.......and keep that saw working.......they LIKE to work, a LOT!
Re: Mix ratio
Robin Corell
>I have a 1974 vintage 051 and when I put new rings in it I asked about the ratio because up till then I too had two diferent gas cans, a huge hassle. I was told that the new oils are significantly better. also when a saw runs out of fuel, a common thing, the mix ratio can aproach 80:1. Stihl designs all their saws to run at this mix ratio to avoid any cumulative damage from repeatedly running out of fuel. as Keith stated it is just a matter of adjusting your jets. I also find the old saw is also more sensitive to having a cloged air filter then my newer Stihl
Keith Tompkins
Re: Mix ratio
Keith Tompkins
>The second I feel my saw running out of fuel, I shut it off....no fuel equals no oil. Alcohol additives are corrosive, and can eat rubber parts, such as the carb's diaprahm and o-rings.
Hmmm, I'll have to try that
>Thanks Keith. I need to replace the plug and adjust the carburator anyhow, so I'll try it with 50:1 mix this time.
