Ques, while on the subject of tool handles
Dominic Greco
>Didn't want to hijack the thread going on below.
I have a Benjamin's Best 1" Skew whose factory handle I really don't care for. After the Christmas Rush is over, I plan on replacing the handle with one of my own shop built ones.
Replacing the handle on a tool with a round shank is a piece of cake. That I can handle easily. However, I'm not sure about replacing one such as my skew, that has a tang.
My thought would be to drill hole in the end of the black which is sized to the average "diameter" of the tang. But how do you stop the handle from cracking when you force the taper of the tang into the hole? It's like driving a wedge into end grain.
Thanks,
Dominic
Re: Ques, while on the subject of tool handles
Rick Allen
>That is what the brass ferrule is for, to keep from splitting the tool handle.
I have heard that heating the tang with a torch and then pressing the hot tang into the handle is effective. I cant remember if the wood is supposed to be green or not for this.
I have found in use that the skew will push the tool into the handle. This is to say that the handle is primarily used to guide the skew and extend the length (provide some leverage) of the tool. The handle is not used to provide a tug of war grip on the handle. It is a good idea to have the receiving hole a bit deeper than the tang will initially sit so that in use the tang can penetrate deeper into the handle. For this reason the tang should not be fully seated in the handle. There should be some exposed tang when the skew is first set so that there is room for the tang to work deeper into the handle during use.
My advice come from my meager experience and from listening to others. Naturally, any advise you may get to the contrary is very likely better advise.
Re: Use a Stepped Hole and Ferrule
Brian Hahn in SW Wisconsin
>With flat-tanged tools I always drill a stepped hole that will firmly hold the tang at both ends. That gives it the best support short of bedding it in epoxy. A tight ferrule should keep the handle from splitting.
If you are really worried, heat the tang red hot and then drive it into the hole. The heat will soften and char the wood and gives and extremely solid and tight fit. I had to chisel the handles off the tangs that I did this way when I wanted to up-grade the handles.
Mozactly
Ed in Sptbg.
>Dominic, turn the handle to the desired shape with a ferrule of the required diameter on the end. Then drill a series of 3 or 4 stepped holes in the end that correspond to different "diameters" and depths along the taper of the tang. Add some super glue or epoxy and tap the handle onto the skew tang.
Jorge Castaneda
>Hi Dom,
Been there, done that, the method was suggested to me by Todd Huges in the hand tool forum:
with a small drill go near the final depth, then with increasingly larger diameters and decreasing depths rough out the hole, keeping it smaller than the tang.
Place the tool in a bench vise with only the tang protruding to the desired depth, fire your torch, propane or better yet map gas and heat the tang until it is a dull red, put the torch down and pound the tool handle against the red hot tang, it will burn its own cavity to just the right shape, there will be smoke and so do it with good ventilation, it takes a lot longer tp explain this than to actually do it.
It work great! And no need to worry about burning the tool handle, the lack of oxigen puts the fire out and it and you get a very tight grip on that tang. It will not alter the temper of the tool either, as it is far from the cutting edge and the vise acts as a heat sink.
Jorge
eliot d
>Jorge, Now that's a clear explanation! Not that the others were not, but beautifully explained.
Another tip for the ferrule: turn the place where the ferrule goes so its diameter is just a few thousandth too large. Then heat the ferrule with a torch, which will expand it just enough to fit, and put it on. When it cools and shrinks, it will never come off!
>Oh yes it will. I did that trick with the ferrule for years. The do stay on for long time but eventually they come off. One trick I've learned is to score the inside of the ferrule really deep. I do this with the corner of a HSS cutter but you could probably use anything that will scratch the brass or copper. Then when you heat it and force it over the tenon you get some mechanical bite.
By far the best thing I've tried are compression nuts. They are threaded. You turn the tenon down until the nut is a force fit. I thread them on with a crescnt wrench. Once this is on it won't come off. At least not in the 10 years since I've made the first one using this technique.
robo hippy
>Another method you can use, if you have the necessary flat work tools is to make a 3 piece/strip handle. The center strip is the same thickness as the tang and slightly wider than you want the finished handle (about 1/4 by 1 1/2 by 18 long). The outside strips fill in the square for turning a round handle. Before glue up, you cut the proper notch in the center strip to fit the tang. Contrasting woods look good.
robo hippy
TDRice
>I like that idea. It will look really good and help identify your tools if you get into a class or other situation where there are other turning tools.
Steven Antonucci
I just did this with a two piece handle
steve antonucci
>I made a small chisel (3/16") from some key stock. I wanted it to look a certain way, so I resawed some white oak and jointed the resaw. I then trace the outline of the "tang" and mortised it out the proper size (by hand, could be routed?) One of the two sides is thicker by the width of the tang so that the tool is centered.
I clamped the two pieces together with the tang in place and some wood glue- and it's rock solid!
Steve
Thanks everyone!
Dominic Greco
>As usual, I got some great advise here. Although, it appears that my need for a torch just got stepped up a notch. At least I can use it for scorching bowls as well.
As far as the ferrule goes, I still have some 5/8" compression nuts left over from when I built those 3 point and half round tools.
Thanks again,
Dominic
Russ Fairfield
>There is no need to make this complicatedf.
Drill a straight hole and fill it with epoxy. It won't go anywhere. You won't need a ferrule because there is no stress on the wood.
If you want a ferrule, a few wraps of #14 bare copper wire makes a good one. Tuck the end nearest the tool under the wrap. Bend the other end over, poke it into a drilled hole in the wood, and seal it in with a couple drops of CA glue.
>Russ I made a tool medium sized tool once using dental floss as the ferrul. I had to make the tool really quick and that was just handy. I soaked it with CA. I used that tool for about 6 years before the Floss came loose.
And no cavities! :-O
Joe Pack
eliot d
>I'm happy to bow to your greater experience. My sample is really only of size one. It was skew chisel that I made that way , and I had occasion to get it off several years later. I can tell you that I had to destroy it to do the job.
