Beal buffing too fast?
eliot d
>I used to do do Beal buffing on the lathe, where I could control the speed, but I got tired of mounting the stuff; so I recently dug out an old (cheap) wheel grinding setup, removed the wheels and guards, and attached two of the Beal buffing wheels to it. -- one for tripoli and one for the white diamond compound. So I have a dedicated Beal buffing station ( at least for the first two steps.). But now it runs at 3500 RPM! It seems to work just fine, but it sure does zip along! Did I do something that could present a dangerous situation? I did fasten it down very securely.
Re: Beal buffing too fast?
Just be careful ho and what what you buff.
Don Henthorn
>Could create quite bit of heat.
>Melting the finish and the grabbing the wood out of your hand are the only real dangers. Use a light touch, always buff down hill and never with an edge pointing up, and don't stay in one place to long and you should be OK.
Russ Babbitt
>Beall recommends 1725rpm.
Sam Scalzo
>I use the beal system all the time but I mounted two wheels on slow speed motors(1750 RPM) then I put one on my lathe so I can control the speed. Slow speed is the best. Sam
bob davis
>BEALL RECOMMENDS 1725 EXCEPT BOWL BUFFS AT 3450...SO BE CAREFUL VERY EASY TO BURN
Bob Fawcett
>I run my Bealle on the lathe. Since I have a choice of speeds I have tried several. I like to run mine between 1250 and 1350. That seems to work best for me. Your mileage may vary.
By the way, the long adapter that is available from several sources gives great access to the wheel from a variety of angles.
Russ Fairfield
>Higher RPM can be good because it makes the wheel harder and more more aggressive. That means buffing can be done faster. It also means that it will remove the surface finish faster, gets hot faster, and throws it twice as far and twice as fast when it grabs it out of your hand.
