We value your privacy.
In last months FWW Bob Smashler makes tool handles for chisels... Where does he get the leather washers for the striking end? Is there a site that shows how to make them? The article doesn't talk about how to attach and shape the washers...
The second question is around turning tools... I want to add some weight to homemade bowl gouge handles...lead shot (buck shot) seems like the best choice, but I can't seem to find it anywhere. Any suggestions on where I can buy it?
>I don't do any shooting, but wouldn't a good place to get shot be a gun shop? I think I heard somewhere that you can't get lead shot anymore; but how about steel shot? It would still add weight. I got some kind of shot a about eight years ago at a gun shop to put into the legs of a stereo table that I built. (Back then, I think it was, indeed, lead.) Of course the last post would get you lead, but melting it may be song and dance.
>... gun shops for reloaders would have a good substitute such as bismuth or whatever they're using now. Don't pack the shot in too tight- it absorbs vibration/movement better if it has a little room to move around.
>I haven't needed to replenish my lead shot supply for years thanks to a reloader friend who was moving and had to get all his stuff in a trailer with a severe weight limit. However, I believe you can still buy lead shot at any sporting goods shop that handles reloading supplies. It is still in use for upland game birds and trap and skeet shooting.
>Try Wal-Mart or similar store, in the sporting goods section. You can by a Pint "milk carton" full of B-Bs for about 5 or 6 bucks. That's what I used in a lot of tool handles. It does absorb shock, just not quite as absorbent as lead shot. Solid lead will add weight, but (I think) not shock absorbency. HTH
>Not sure about this, but I think you can get leather sheet from a fabric store. My brother reupholsters car, boat, and small air plane seats on the side (as well as dentist's chairs). He buys leather sheets on occasion. I should ask him.
After you get the sheet, then it's a simple matter to punch out whatever size circle you need using a leather punch. Actually, sharpening one end of a piece of appropriately size pipe would work just as well as a purchased punch.
The simplest answer to question #2 is bee-bees. Lead has a density of 11.4 g/cm3. Copper is 8.9 g/cm3 or 78% that of lead. That's close enough. Iron and steel run around 7.1 - 7.8 g/cm3 -- not as good as copper. If you want to go for broke, gold is 19.3 g/cm3 -- 69% heavier than lead.
For the leather washers, try Tandy Leather Company. Tandy sells leather and leather working tools to hobbyists. They should have a punch that will cut suitable holes in a sheet of leather for your handles -- they might even have a supply of ready-made washers for sale. Tandy has stores in many parts of the country. They also sell over the internet. Here's the address: http://www.tandyleather.com/ If a store were handy, I'd ask them to recommend something. Over the internet I'd just order a belt blank (a strip of leather).
When I was a kid, Tandy and Radio Shack were two of my favorite stores. I didn't know, at the time that they were owned by the same company. Thinking about Tandy, I'm getting all misty eyed....
>Can also get small pieces of leather at any hobby store. Can hold on the handle with contact cement (leather workers use Barge cement). Put the leather between two pieces of thin plywood and drill a hole of the size you need.
>If you are making turning tool handles to use for deep hollow turning, then lead or other weights added to the handle are a good idea. You can use the weight to counter-balance the forces created when you have your tool extended way beyond the tool rest down inside a turning.
But like all good ideas, this has been taken to an extreme. People are now weighing down handles used for regular spindle or bowl turning. Why? I don't know. To counter-balance the fact your tool is extended way out over the tool rest? There is no reason for it being out there. Adjust the tool rest. A big gap between the tool rest and the spinning wood is really dangerous. As for working with one of these heavy tools all day -- well, your elbows will soon be down at the level of you knee caps. They are far too exhausting. When doing spindle or bowl turning, I go with the lightest handle I can get. There are a number of good commercial ones out there -- or you can make your own. If you do make your own, consider making the diameter of the tool handle significantlly larger. It cuts down on hand cramps. And, if you have arthritis, or the beginning of carpal tunnel problems, it will ease the stress and let you continue to turn. (It is also good for avoiding these problems.)
>There's another option. Simply make the tool handle longer. My heavy duty rough out bowl gouge has a handle that's 3 feet long and about 2 1/2" in diameter. It absorbs the vibration of rough turning large out of round pieces. I do keep the tool rest as close to the work as possible but the extra weight and length of this handle makes is a pleasure to use.
The downside is sharpening. Right now it's not a problem because I moved my grinder so you can swing that big thing. What I plan to do is what Clay Foster recommends which is to make the tool removeable from the handle. This lets you remove the tool so you can easily sharpen a shorter shaft.
>Although you can make your own, I find the Oneway ferrules are a wonderful invention. They are easy to fit on a handle, are sturdy and have two allen screws through the thick Aluminum to hold the tool very firmly. Well worth the money. And they make it a breeze to remove a tool for sharpening. I usually do that when I sharpen because the handle on my bowl roughing gouge us 2" in diameter and 21" long (handle only). Other tools are the same diameter and about 17 inches long. The biggest handle works on my lathe because I have a 24 inch swing. For smaller lathes, I would recommend the shorter handle. Otherwise the lathe bed will get in the way as you swing the tool on some cuts. (I have to switch the roughing gouge into a shorter handle when I am using the club DVR for demonstrating.) As for diameter, 2" works for me because I have relatively small hands. Others may want to go bigger.
>Thank you all for the good information. I have a Glaser bowl gouge that I love... and want to recreate the vibration free use with that gouge.
I'm not too worried about the weight as I'm a fairly burly 31 year old, but I will also consider a longer handle... seem like it will do a good job of providing leverage on a roughing gouge (otherwise I'd be worried about having too much handle to swing around during sharpening... or over my standard length lathe bed).
