Re: Raffan's Box turning video
Fog Tanner
>Like a lot of turners, I used the Raffin finishing method of Beeswax. I have used straight beeswax along with some that I mixed boiled linseed oil and turpintine (beeswax is metled in a double boiler and the other to are added outside). The mixture I use is about like firm butter and softer than pure beeswax.
You just build up a layer and hold the cloth against the piece until the wax starts to melt and then push it along the surface. I use a rag for this and after a while it has enough wax buildup that you really don't need anything more than the rag. For pieces around 2"-2 1/2", I am generally spinning between 1500-2000 (depending on the mood).
In the videos, Raffin uses mineral oil but in the demo and hands on he used boiled linseed oil. I use both, just depends on the wood and look I am after.
