Router/ Lathe Jig Help Please...
Jim Shaver Oakville, Ont.
>Hi,
I am currently working on a spindle project that I will soon need to use a router with as well to add some details. I have a beading detail that I can accomplish with a new bit I just bought.
I would like to know if any of you have built a lathe jig for a router and maybe share some details. The router would need to be captured in the jig in a vertical position and slide in and out flush to the ways on the lathe and traverse the length of the spindle work, about 10 inches long. I want the bit to cut the spindle bead details at the height of the centre line between the headstock and tail stock.
Thanks,
Take care,
Jim
Re: Router/ Lathe Jig Help Please...
John in Kerville
>See if you can locate a copy of Bill Hylton's Router Magic. I also think Ellis and Bill co-wrote a router book that had one of these.
Also check out Pat Warner's site, patwarner.com
john
David Walser
>Jim,
I can't give you details of construction, but I've seen a couple of the kind of jigs you describe. However, instead of having the router mounted at the side of the lathe, the router was mounted above the lathe. The turning was turned via the hand wheel to the appropriate index point and then the router was lowered into position and the cut was made.
Allen Neighbors
>Jim, I believe John Lucas made a jig that would hold his small router, and follow the contour of the piece. Not sure, but I think it was he.
I wanted to try to build one of them and lost the information, and since just haven't gone looking for it.
Maybe he'll be on here soon, and see this, and give us the heads up if it was he that made it.
John Kyler
>You might look at the Vega duplicator with the router attachment also.
John
>Jim I do have a jig that I have built that should give quite a few options if modified. I'll try to post some photos tomorrow.It's late and I've had a long day of work followed by a club party. I'll have to downsize the photos. I designed this router jig so that it can easily be modified to do a lot of different things.
>After reading about Frank Sudol passing I'm kinda keyed up so I dug out the photo of my router jig and shrank it to fit. I made this jig so it fits on the side of the piece. This gives me more options. The whole jig slides in and out for a sort of course alignment.
The riser box swivels 90 degrees. This is to give me some fine tune options. I plan to redesign the box so the height is adjustable. Partly to fit other routers but also to be able to route above or below the center line. This is handy when routing on platters.
The top platform also slides in and out for fine adjustments and also to allow other jigs to fit so you can make the router track the shape of the piece. In this photo it has a straight fence for routing flutes on collumns but you could very easily put a curve fence to route curve pieces or to put curved slots in straight pieces.
The top platform can be rotated 180 degrees so I can quickly change from one fence to another. By attaching a curved fence vertically you could route flutes that run around the piece.
Re: Pic didn't make it, John
Allen Neighbors
oops-you have to push the buttons
platter routing
>I forgot to mention that you can use the ends to route platters. The photo shows me using the sides with a fence to route between centers but you can just as easily put a fence on one of the ends and route or carve into a platter like surface. In the one pictured below I used a V shaped router bit.
90 degree V bit routing
>This is the same technique as the platter but routed into a cylinder that lather became a christmas ornament.
castle bowl routed with index plate
cutting the maple castle bowl
>In this case I used a vacuum chuck to hold the bowl because this was a bowl that was already completely finished and I wanted to add the detail to the rim. I would usually do this while it's still on the chuck or faceplate. Aliging it in the vacuum chuck was tricky but that's the beauty of using a vacuum chuck, you can do something like this.
test
Norm Smith in Nova Scotia
>test
Re: test
test pics are of a jig I made
>The table is a piece of countertop with a face plate added. I purchased a 1" bolt that threaded into the faceplate. I cut the head off of the bolt so that it would fit my banjo. On the table I can clamp a stop wherever. The table can easily be moved up or down or in any direction.
The jig for the router is self explanitory.
I never posted pictures before , that is why the test. I just took the pictures this am so I am sorry the messy shop.
Hope these help.
Norm
Another jig
jgrounds
>Someone mentioned the Router Magic jig. Here is a variation based on that jig:
Re: Another jig
Monty Bates
>That looks very good! How about more pictures and information.
Great job Norm. Simple and effective.
Re: Great job Norm. Simple and effective.
>I might consider building the same thing but I'll use a piece of threaded rod. That way I can put a nut on it for fine tuning the height.
Re: Another jig
>Ooh that's incredible. I want one. I have a Nova Comet sitting in the corner right now and I'm sure I have some bicycle gears.
Truly a jig of beauty. Does the job with no fuss.
Craig Daymon
>Very nice work Norm. Thanks for sharing. The best jigs are always the simplest. Amazing how often we can't see the simple solutions. Again, thanks. (I'll see about giving myself one for Christmas. Don't tell.)
-Craig
Thanks All
>Hi,
Some great ideas, thanks for the postings, links and pictures,
Take care,
Jim
Russ Fairfield
>Several of the basic woodturning books have these router jigs shown. For one, I know there is a description in Keith Rowley's book, "A Foundation Course".
Ed in Leaside (Toronto, Ontario)
>Hi Jim,
I had to mortise a few spindles once at exactly 60 degrees. The lathe didn't have indexing so I came up with this router sled. The protractor was drawn in Illustrator and printed to an overhead transparency sheet (mirror image). Turned some nails for centres.
Ed
