Re: Epoxy Problems
Robin Corell
>You've gotten some good comments and advise so far but I wanted to add one common source for epoxy failing to set. Unlike polyester which can be kicked with an additional coat of properly mixed resin, epoxy that is not mixed properly will never set. a source of unmixed resin is the sides and bottom of the container as well as the mixing implement. It is common to want to use every last drop of an expensive material by scraping every last bit even more than when you scraped the sides when mixing. A remedy for this is to pour the resin into a clean container (don't forget to scrape the sides really well) and then use a clean mixing impliment (aka a stick). Mix it a bit more then feel free to use every little bit you can coax out of the container without fear of it not being mixed properly.
Of the many diferent resins, epoxies, and rtv rubbers Ive used, as long as the temp dosent fall below freezing as soon as the temp is brought above 70 it will resume the curing process. I used to use this property to my advantage in hot weather by storing my resin in a refrigerator I had for that specific reason so I could gain a few extra minutes working time. This works with bondo too.
as for your project it is time to dig it out. If part of it is hard then just clean it off really well and fill it back up with the same material. It is is soft all the way through it is likely it was either not mixed properly or the producct has expired. Either way I would recomend doing a small sample befor refilling your turning with the same product.
Robin Corell
