Lathe height
Dan Clermont in Burnaby
>Hello Everyone
I am setting up a station for my Jet mini lathe and trying to determine if height matters. I am 6' 3" and have found that the countertop I am currently using is too low.
TIA
Dan Clermont
Lathe height
>Hello Everyone
TIA
Dan Clermont
Re: Lathe height
Mike Cunningham (Cape May NJ)
>A starting point would be the height of the tip of your middle finger from the floor with your arm flexed and forearm parallel to the floor with your fingers extended. I'm 6'4", the mid-point of my spindle is 50 1/4" which is about 1 1/4" higher than the measurement described above. I like my lathe raised high. I have a portable platform of 2X4 and 3/4" ply for shorter turners.
There's a thread regarding this on Friday Dec. 8....do a search.
Mike
Re: Lathe height *LINK*
Darrell Feltmate
>Dan
If the counter you are using is "too low" then obvously "height matters," at least to you and you are the one turning. A rule of thumb is to have the lathe at elbow height. A nice thing about the mini is that it is easy to jury rig a stand and try it at different heights to see what YOU prefer. I did the same thing with my full sized, but at 200 pounds it is more than I want to heave around to do that again. I notice that my three stationary lathes are each used for slightly different turning and each are at slightly different heights.
Around the Woods
Re: Height does matter...
Allen Neighbors
>Here's a pic of my lathe raisers. My spindle is at 49", and since I raised it, I haven't had any more back problems.
Re: Sorry, I didn't explain...
Allen Neighbors
>that the platform is two 2x6's cut to size and stacked, and screwed to the floor. The black thing in the middle is an electrical pedestal to plug in the lathe and other power tools. The black is a "skirt" around it to keep shavings out. :o)
