signing work
signing work
signing work
>Here are some samples of signing work with a dremel engraver and a woodburning tool. You can see the quality of the signature is more dependant on the quality of your handwriting than the tool.
The one on the top left is the dremel filled with gold wax. The one one the top right is the dremel with shaky hands
The ones on the bottom are pyrography using the Optima burner with the modified writing tip. I'm still learning to use it and it varies with the wood species.
I've signed several dozen pieces since getting the burner and still can't sign any better than my dremel engraver. It's more sensitive to summer winter wood variations than the dremel is. Both require a light touch and lots of practice.
If you have bad handwriting the only thing I can suggest is practice. My signature is much better than my handwriting. I practice it.
Don't know that this proves anything one way or the other I just thought you might find it interesting. Obviously either tool works and at least in my hands the dremel isn't any better or worse than the burner. the Dremel also shows up well on dark woods, especially if you rub colored wax into it.
Re: signing work
Re: signing work
John Kyler
>But how do you sign the micro turnings? :)
John
Re: signing work
Re: signing work
Ruth Niles
>John, I had trouble getting a smooth signature, too. Then I watched Bonnie Kline use a little engraving tool and it works great. You can write really tiny on small bases and it's easier to control.
Re: signing work
Re: signing work
>Ruth do you know what kind of engraving tool she was using. I've seen some small air powered tools and often wondered about the medium high speed rotary tools. The have some electric and air powered that go up to about 56,000 rpm. I tried the dremel rotary tool with thier engraving bit and it's way to hard to control and leaves a thick line.
I'm going to try some different burning tips after christmas. I still can't control them accurately enough on some woods. The temperature seems to be really critical and if you didn't save any scraps to play with it can get challenging.
Re: signing work
Re: signing work *LINK*
Stuart Johnson
>What about a pencil die grinder like the one below? I receive mailers from time to time (Enco?) with them for sale around $60.
pencil die gringer
Re: signing work
Re: signing work
Ruth Niles
>John, it's called an electric Fibro Engraver. Bonnie used a red one and that's what I bought but all I can find doing a google search is this black one. It look identical.
