A55 Smoothing Plane
REAL BIG LATHE!!!
REAL BIG LATHE!!!
Dick Hines
REAL BIG LATHE!!!
Dick Hines
>I was working in the Newport News Shipyard yesterday and went into the shop where they turn the prop shafts for the ships. Ther were 2 lathes that had to be 40 Ft. or better long. One of them had a face plate that was 6' across. I did not see the name on the lathes as I was on the third floor and they were on the first.
Now a lathe that would do spindles 40' X 6" is one big lathe. I hope I get to see one of them at work ont of these days.
Re: REAL BIG LATHE!!!
Ken Oakley-Sunny St. Cloud, Fla.
>Back in the 50's the company I worked for was contracted to make a plant layout model of the Westinghouse Steam Turbine plant in Pittsburgh. If memory serves me they had a lathe over 100' long with an 18' diameter chuck. The tool bit had to be inserted in the tool holder using an overhead crane. Three machinsts rode on the carriage and it took an 8 hour shift to make a cut the full length of the shaft being turned. They had to use two 50 ton overhead cranes to lift the shaft so it could be chucked in the lathe. I remember being told the foundation under the lathe was 22 feet of reinforced concrete.
Big Iron----
>Somewhere on the web I saw a photo of a lathe turning an armature for a ship engine. It was 8 or 10 feet in diameter and about 30 feet long. They said it took 8 hours to make one pass of the tool.
Not as big but...
Bob Fawcett
>I worked on this one.
In the late 60s I worked in a machine shop in South Florida. We had a lathe that the owner had modified to swing 52". The bed was 24' long. Amoung other things we made the hinges for the flood gate doors in the levee around Lake Okeechobee.
