New Jet lathe question
Alfred Poor
>My 30+ year old Sears Companion lathe finally gave out, and I just bought a Jet mini as a replacement. I couldn't get it to run, as the GFI circuits would trip when I try to start it. The Jet tech support folks emailed to say that it can't run on a GFI circuit. I'm willing to accept their statement, but can someone explain why this is the case? (I hope I have an unprotected circuit in the shop somewhere....)
Re: New Jet lathe question
Dick Hines
Dick Hines
>I may be caused by the power surge. You did not say how big your lathe was. The bigger the motor the bigger the surge. I have a Jet mini that is behing a GF plug and I have had no trouble.
Gary in Zirconia, NC
>I have no trouble with a GFI with my Jet mini.
Mike from Tn.
>I'm not an electrition by any means and I haven't seen the specs on the mini but it couldn't pull more than 20 amps. If your not overloading the GFI somewhere else on the line perhaps the mini has a built in GFI thats malfuntioning? I've never heard of a a tool that won't run on a GFI. I know that there's a differance between a Ground fault and an arc fault but I couldn't tell a third grader what it is.I hate to see a brand new tool right out of the box that won't work. Happend to me more than once. Good luck
Hooligan
>Same thing as any variable speed running on a GFCI, it most likely won't run. There is something that relates to the current flow, and how it regulates. It isn't an amperage difference, it is the milli-amperage. It actually has to do with the variable speed.
Newton's law of something or other relates to it. Can't remember which.
RevDoug
>Hooligan, what you can't remember is the feedback of the VFD. That is what the problem is with the GFI plug.
Turn 'em round,
Ric Taylor
Ric Taylor
>Alfred,
I'm not an electrician, but it sounds like you have the Jet mini with the variable-speed motor. For some reason, variable-speed motors don't get along well with GFI curcuits.
I had the same problem for a loooooong time, my lathe kept popping the breaker. Once someone told me that I shouldn't try to use it on a GFI curcuit, I plugged it into a regular outlet, and I haven't had any trouble since.
Ric
Alfred Poor
>Thanks for all the quick responses.
1. Sadly, this is not the variable speed model, so the variable speed factor can't be in play. (Variable speed was an extra $175 on Amazon, so I spent the difference on a chuck instead.)
2. I've just checked, and my electrician was all too thorough in wiring not just the shop, but the entire area around it as well. I have no outlets that aren't protected by a GFI.
Is the solution as simple as replacing a GFI outlet with a standard one? I'm comfortable doing outlets and light switches, so I'll do that if that's the fix. I'm puzzled, however, that some people are able to run their Jet on a GFI circuit and others can't. Perhaps it has something to do with the specific motor used in the different units.
Rick Christopherson
>Hi Alfred,
Ellis Walentine asked me to stop over here and look into your question. The reason why your lathe is tripping the GFCI outlet is most likely due to the starting capacitors. The capacitors are kind of like a battery in that they store some electrical energy for a short period and release it a short time later (so is the motor too). Because a GFCI outlet works by comparing the current in the two wires feeding the motor, there is an instantaneous time period where the two currents are not exactly equal. This causes the GFCI to trip.
GFCI�s are there to protect the operator when he/she is plugging/unplugging the device. They are not necessarily there to protect the operator while the device is running. Granted, GFCI�s in bathrooms and such are in fact intended to protect the user even after the tool is plugged in, but when it comes to larger tools, this is not necessarily the case.
Your best bet is to remove the GFCI protection from this single outlet, however, I believe I also read that you were not able to isolate this single outlet without removing all of the GFCI protection in the whole shop. So that may not be a good choice.
More modern and sophisticated outlets can actually account for these conditions and hold off on their trip point until they are sure the cause is not from a motor-type load. Your next solution would be to buy a better quality GFCI outlet and replace the original. Try to locate one that is rated for light motor loads. I don�t know if you can find these at home centers, so you may have to go to an electrical supply outfit.
Bob Fawcett
>Alfred,
Are all your outlets GFCI, or is there one to protect each circuit?
Many GFCI outlets can protect the entire circuit which may be 3 or 4 outlets. If that is the case, simply replace the one that trips with a regular outlet.
Hooligan
>Thanks Rev, I knew it was somewhere in there!
Alfred Poor
>Thanks Rick (and Bob and everyone else, and thanks to Ellis for flagging my message).
All the outlets on all the circuits in the shop are GFI protected, but each circuit appears to be controlled by one GFI outlet on the circuit; I can find the one that trips when I try the lathe. So I've already identified which one I'm going to remove so that I can use the lathe. I'll just swap that out, and I should be in business. Thanks all for the quick and thorough explanations and advice.
