Have a question? Ask Woody!
Beale Buffs on the lathe
Leslie S
>Hi folks.
I the motor for my Bealle finally but the dust and I will be using my lathe to buff and get through the season til I can replace it. What do I use to hold the buffs? I don't want to crush the threds on the buffs.
Thanks for the help,
Leslie
Re: Beale Buffs on the lathe
Steven Antonucci
without seeing it...
steve antonucci
>I'm guessing that you can turn a wooden "holder" for a chuck, and simply drill a hole in the middle. Then, use the thread to tap the hole.
Steve
Wally Dickerman in Arizona
>My Beall system came with an adapter to fit a 1/2-in. motor shaft. I cut a short length of 1/2-in steel rod to hold the adapter and fits into the small jaws of my chuck. Gives me variable speed for the buffs.
Wally
Bob Way, Canton, MI
>I picked up an accessory that fits the #2 morse taper of my headstock and it has a threaded hole on the end to accept the Beall buffing wheels. I believe it was an item offered by Beall, but I'm not positive. It does need to be well seated, or at least held in place through the head stock, because it does have a tendency to spin itself out if it isn't.
Bob Way
Re: Beale Buffs on the lathe *LINK*
Rick Allen
>The way I attach the buff to the lathe is with a "long buffing adaptor".
This is availble from a variety of sources. It works GREAT!
Long buffing adaptor
>I have one of the long buffing adaptors and love it. It gives you enough room to do some pretty large stuff.
Dick Hines
Dick Hines
>The buffing adapters can be had from Wood Turners Catalog. Page 73 in the catalog. Ther come in 5 thread sizes from3/4"-16 top M33-3.5.
Paul Porter
Or try Don Pencil's adapters... *LINK*
Paul Porter
>...I have one and am very happy with it. See attached link.
No affiliation, just a happy customer.
Don Pencil
eliot d
>I have exactly this set up, and , yes, the morse taper has a tendency to spin out of the spindle. what I do is to place a little hard rubber plumbing washer at the end of the threaded part and bring the pointed live center up and into it to put pressure against the headstock. It just can't spin out this way.
Bob Way, Canton, MI
>What a good idea! Thanks for mentioning it.
Bob Way
Leslie S
>Hi,
Thanks for all the great ideas, I will be buffing my heart out by Saturday afternoon.
Happy Turning!
Leslie
Stuart Johnson
>I sounds like you have the same set up I have. You can thread a 1/4" bolt in the end. I use all thread through the headstock and a wing nut with a washer to hold it in place. It just needs to be snugged down to prevent the slipping.
Re: Or try Don Pencil's adapters...
Bob Fawcett
>Thats the same adapter. I got mine at Craft Supplies like the previous link, but is the Wood N' Things adapter.
