I can dance, I can dance all night...
Robin Corell
>When I bought my delta 1460 from an Oregon state surplus auction it came equiped with a foot switch. When it was delivered I was under the gun to deliver some patterns so I just pluged it in and used it. I really didn't want the foot switch and figured I could scrap it out later when I wired in a pull-up-to-start switch on the top of the wood base directly above where the back end of the motor is. I had turned on a lathe of the same model with a switch like this and had liked it very much. No accidental starts and easy to hit to turn off quickly. The switch is actually a standard single pole switch on tho motor with a long metal rod that has a ring on the top end and a slot on the bottom where it attaches to the switch with a kotter key.
Ive seen the same set up on a couple of old delta bandsaws but I have no idea if it is a stock thing on their lathes.
The foot switch that my lathe came with is one of those industrial units with an orange steel cover that is big enough to acomodate my size 13 work boots. The switch is wired in with heavy extension cord type wire and can be positioned anywhere around the lathe. It is the type of switch that you step on to start and step on agasin to stop. It took some getting used to and I did occasinaly swear in its general direction but now I find it convienient and no longer have plans to change it out.
I don't quite understand how dancing and a foot switch are exclusive. I must be doing it wrong or its the music I listen to. (Taj Mahal at the moment)
Robin Corell
