Signing One's Work
Signing One's Work
Signing One's Work
Terry Fox
>I've been turning just long enough to be able to make a piece or two that I'm willing to put my name to. I'd like to see opinions as to the methods you have chosen to do this, such as pyrography, engraving, dremel tool, ink pen, etc. Also pre-finish, post-finish, any other methods that escape me.
I don't post much, but I read it all. You all are a great help and a great community.
Thanks, Terry in PA
Re: Signing One's Work
>I've tried most of the ways out there and my favorites are these.
Dremel engraver. With a light touch you can writed really neatly and this shows up in both dark and light woods. For a nicer touch rub some gold wax into the engraving. You do need to sand the work carefully where are signing, this makes it easier to write.
Pyrography. I have the Optima woodburner and use what they call a modified writing tip. I would strongly recommend a good brand of woodburner rather than the cheap ones. It just makes it easier to write. Sanding is also necessary here and the writing technique takes some practice with a light touch.
Permanent marker pens. I use these on smaller items like ornaments. Look for pens that say they are achival. I use the sharpie markers mostly. Some inks will run with certain finishes so do a test with your markers and your finishes. Also some markers will rub off of some finishes so you might need to apply another coat of finish over the marker, however this can smear the name so again, do a test.
Branding iron and pen *LINK*
>I used to put my little logo on there with a Sharpie pen, until I had a custom branding iron made. Now I chuck the iron in my tailstock, heat it with a blowtorch and run it right into the center of the bottom of the bowl or whatever. Then I put the month and year on in black fine-point ballpoint pen. The ballpoint ink doesn't soak in like the Sharpie ink.
Ellis Walentine, Host
PS, Rick Herget is an ace engraver who makes these irons. He's been at it for over 40 years and I can't imagine anyone more skilled, even at reproducing your signature. He's also a WoodCentral advertiser.
Rick Herget
eliot d
>I apologize for hijacking the thread (although I think Terry may be interested), but whenever I sign with either an engraving tool of some kind or with pyrography, I always seem to have trouble because of the hard/soft/hard wood grain, which caused the tool to wander and spoil the clarity of the signature. Any thoughts on this problem?
Re: Branding iron and pen
David Hammond, in Powder Springs GA
>Ellis, I agree 100 percent. I had Herget make me an iron, and it modeled my artwork perfectly!
David
I don't have a great close-up of my iron, but here's the bottom of a bowl which exhibits how I sign my work - the signature and #'s are done by hand with a woodburner, and the logo is the Herget iron, which says "My Dad & Me".
>I used to have that problems and still do occasionally. The trick I've found is to lighten up the pressure on the tools. This is especially true on the woodburning. Set the temperature so you can just sort of glide across the surface. some woods like Fir or Pine that have really wide winter wood require you to slow down while writing through that section.
With the dremel engraver(this is the engraver not the bit they sell for regular drememl rotary tool) if you just lighten up the pressure it will usually write quite nicely.
David Breth
>I know this is kind of swimming upstream, but I still like using the old sharpie (a silver-colored one for dark work). Granted, I'm a hack turner, but I like that it is my name written in my hand with a writing instrument. I also like using my printed name, and always do so in the same half-circle pattern.
Someday, as things are passed to kids/grandkids, I don't want there to be any question about where they came from. Many of the turners in my group use just their initials. I can never figure out who made something, and fifty years from now their grandkids won't be able to figure it out either.
This falls in the context of trying to get my parents to label photos......
two cents. You've got change coming.
David B.
Donna Banfield
>I've used a fine point sharpie in the past, but as has been pointed out, it will rub off eventually.
About 3 years ago I acquired the Cub Woodburner, and two pens. I used the fine point to sign all my pieces. I have one of Dick Sing's books, and he recommended filing the edge of the woodburning tip that you use for signing your work. I did that, and it now gives me a very fine line with which to sign my work. I've upgraded to the Eagle Burnmaster, but still use one of those original pens to sign all my work.
You need to practice -- compare that to when you first learned to write in cursive to sign your name. It's not that different from that. You had to practice your letters way back then, and you need to practice using a woodburning pen.
Allen Neighbors
>Ellis, clicking the banner doesn't do anything on my laptop. Do you have a webpage link for HERGET'S QUALITY ENGRAVING?
Thanks,
David Breth
>The rubbing off thought is a bit of a concern, but I generally have a recess or at least an indent in the bottom of the bowl, so it doesn't get a lot of hand traffic. Heck, none of my bowls get hand traffic, they sit on a shelf all the time, but will the sharpie signatures fade for sure over time?
Anthony Y
>Hello Mr Fox, next time you come to the club meeting ask this question and be prepared. Right Jim K!!
Russ Fairfield
>I have some strong personal opinions about how turned wood objects should be identified. They are probably not shared by anyone else.
Like finishing the bottom, the final signature on the piece of wood is important. It conveys our personal feelings about the piece, our pride of authorship and craftsmanship, and our permanent association with it.
A signature with a Sharpie looks tacky, they aren't permanent, and it shows our disregard for the piece. It begs the question, Why would someone spend many hours turning and finishing a peice of wood, and then only 3 seconds with a laundry marker for the final touch.
A vibrating Dremel tool is better, and it is more permanent; but it looks like what it is, a signature engraved with a dull nail. It has its place, but not on a fine piece of turned wood art.
Branding irons look like what they are, a branded logo. Unless I am familiar with the brand, the maker remains anonymous. Anonymous artists shall forever remaibn unknown.
A burned signature is permanent, shows pride and caring for the piece, and adds a touch of class. To paraphrase the old advertisement, there is nothing like a burned signature to show that you cared enough to do your very best.
As I said, nobody else agrees with me. I know this because I see so many "Sharpie" signatures, and from some world famous woodturners on some very expensive work. That just tells me that, to them, I am worth no more than 3-seconds with a laundry marker.
Well stated Russ
Devon Palmer
Stuart Johnson
>Russ, One problem I have and I'm sure others as well. The only thing worse than my handwriting is my signature. What do you recommend in cases like this?
Peter Teubel
>"I've used a fine point sharpie in the past, but as has been pointed out, it will rub off eventually. "
Not if you sign BEFORE you apply a finish. After that, its sealed in.
