Delta lathe
Delta lathe
Delta lathe
Mike from Tn.
>Thanks for the replys guys. I've talked myself out of getting a Delta 64-715. I'll save a few more pennies and get the JET. This will be my 3rd lathe and I hope it'll be around for several years longer than the first two. Any turners from around Nashville? I don't turn too bad but I need some hands on help with my sharpening. Any clubs around the area I could turn to? Thanks
Re: Delta lathe
Re: Delta lathe *LINK*
>Try the link below. There are about 120+ turners in Nashville. I'm just an hour and 15 minutes away. The tennessee association has hands on classes each month so you could probably get some time in on a Jet 14" to see if you like it. I know there are a lot of different lathes in use by club members so you could probably turn on just about any lathe your interested in.
http://www.tnwoodturners.org/
Re: Delta lathe
Russ Babbitt
AAW Chapters
