10% off at Enco *LINK*
Ed Kelle
>Thru Friday for online orders. I've been meaning to order some HSS for tool making so this is good timing.
the promo code to enter is HDS6C
http://www.use-enco.com
Ed Kelle
Thanks Ed, & a question
Dominic Greco in Richboro PA
>Ed,
Thanks for posting this. I was just about to place an order with ENCO.
Just out of curiosity, what type of steel blanks are you ordering? I was looking through the site and saw the HSS Steel Reamer and Drill Rod blanks for $6.17ea. But they were only 5" long.
I wanted a blank with a bit more length so I could mount it in a handle easily. From reading recent posts here, I'm pretty sure I'm want to go with some type of hardened steel. I'm not one to anneal and harden on my own.
I saw the Air, Water and Oil Hardened Blanks (and they throw in "Shock Air Hardened" just to make it more confusing). After browsing through the site, I saw the explanations for A1, W1, and O1 along with their characteristics. I believe that it's the A2 Steel I want. ENCO states,
"A2 is an electric furnace air hardening, fine grain, fully spheroidized, 100% decarb fine tool steel. It's 5% chrome content gives it an excellent wear and abrasion resistant property." .
Is this the type you were going to order? That description sounds about right.
To make matters more confusing, I have a copy of the AAW Journal in front of me. Fall 2005, Vol 20, No 3, to be exact. There is an article on page 32 titled "Make your Point Tool" by Stacey Hager. In this article he suggests using tool blanks with a hardness of 62 or 63. Unfortunately, I didn't see a hardness rating for the A2 Air Hardened Blanks. You wouldn't happen to know if ENCO carries longer, hardened blanks with this Rc hardness, do you? (hmmmmm,..I guess I COULD call them tomorrow. But that's so LOGICAL.) :>)
I guess this is another case of me knowing just enough to be dangerous. I remember reading about the A2 Blades offered by Lee Valley for use with their Low Angle Smoother (what I asked Santa for this year!). I remember reading that the A2 is the more traditional steel and that it will take a finer edge, but needs to be sharpened more often.
I'm about to place an order for a bur/ball mill cutter and wanted to add these blanks while I was at it. A "sanity check" would be very helpful here.
It's funny, I wasn't planning on buying ANY tool steel blanks today. But when I went to order the bur/ball mill, I thought to myself, "Hey, while I'm here......why not?!". I could always use some blanks to make a couple tools here and there! Ever since I made that 3 point tool, I wanted to make some smaller versions.
See ya around,
Dominic
Re: Thanks Ed, & a question
Keith Tompkins
>Dom, they sell some marked "hss". That's the ones you want. When you call, mention that, they'll hook you up.
Ed Kelle
>I see stuff on pg 54 of the printed catalog that I will order
M2 HSS Rectangular tool bits #383-5761 3/8/ x 3/4 x 5 $6.90
M2 HSS Round tool bits #383-7040 1/2 x 6 $4.28
this should give you other size options as well
I know little to nothing about metals but I think it will be good enough for what I want to do. I don't mind having to resharpen.
I also considered buying Penn St tools, even the straight scrapers and just regrinding them to whatever custom shape I wanted as it isn't much more expensive and they already are handled, so no fitting involved.
Thanks Ed!
Dominic Greco
>Ed,
Thanks for the info! I will use that to place my order (hopefully I'll find some time at work today to do this).
I hear ya about the PSI tools. I live very close to their showroom and browse through the $10 bin every chance I'm there. The HSS steel tools are a real bargain. But those handles are the WORST! What did they make them from, Balsa wood? :>)
Thanks again,
Dominic
Thanks Keith!
Dominic Greco
Enco tool bits *LINK*
Phil Joines Krum, Tx
>If I don't want to harden and temoer them myself (it isn't hard to do) I get Tool Bits. There are lots of sizes. The length seems to be proportional to the width/thickness. Some are available in 6" and 8".
http://www.use-enco.com/CGI/INSRHI?PMSECT=0000000741
Found this on MSC
Dominic Greco
>I called ENCO and spoke to a cust. service rep. She told me that ENCO does not carry longer lengths of HSS rod than those shown in the catalog. She suggested I contact MSC. So I went to their site and found this.
HSS M2 Drill Rod. It's economical, AND comes in 36" lengths.
Sounds like a winner to me!
What do you think?
See ya around,
Dominic
Done deal
Dominic Greco
>After all was said and done, I ordered the tool blanks you suggested from ENCO. MSC had the HSS M2 rod, but the ball mill cutter price was DOUBLE what I would have to pay at ENCO. And You're 10% discount didn't help matters. So I figured, what the heck, they were so cheap I could afford to order a couple. Now everything is coming from one place.
Later,
Dominic
The M2 on MSC is not hardened - kind of long
Brent English
>SEE SAFETY NOTE AT END !!!!
Hi guys, make sure to check out page 1717 on the internet catalog. The M2 High speed is not hardened. It's pretty tough, and you could make a passible simple tool from it in its unhardened state, but it will not be the same as a hardened finished tool you buy with a handle on it.
M2 is very difficult to heat treat in the home work shop. Small pieces of A2 can be he heat treated in the home shop, and for woodworking, A2 is almost as good as M2.
To heat treat the end of a small round rod of A2, use one or two propane torches to heat the material up bright red. Make sure to heat up a couple of inches. You won't have enough heat to get the whole rod hot.
Of course, do this out in the driveway, or at least away from any flammables (like sawdust !)
Before hand, find yourself a nice magnet with with a metal handle. One of those telescoping magnetic "Picker-uppers" will do. When the A2 starts to turn red, test it with the magnet. When it looses its magnetism, it is hot enough that when it cools it will harden.
Then just remove from the heat and let it air-cool DO NOT quench in water or oil. The "A" in A2 is for air-hardening. At that point, it's a little to brittle (might break) and you'll need to temper it a bit. When your wife isn't home, turn up the oven to 450F. Put your blank in there for an hour or so. This draws a bit of the hardness out so that it is not brittle, but still leaves it plenty hard enough for woodworking.
A2 is nicer to heat treat at home than 01 (oil hardening) or W1 (water hardening), because you don't need oil or water to quench - which can be quite dramatic. If you do decide to use O1 or W1, make sure to do this an area where splashing hot oil or steam will not be a problem (like on your hands !).
The magnet is still a good trick to make sure you get it hot enough. The magnet is an old blacksmith trick and it works well. A metallurgist would tell you that the magnet can be used to indicate a "phase-shift" in the metal when it gets hot enough to harden when properly quenched.
SAFETY NOTE: In all cases, observe proper safety, face shield, gloves, long sleeves, clean work area, away from flammables etc. We're all adults here, but sometimes we forget and get careless. Mama may not care if you throw a piece out of the lathe and hit your noggin, but burning down the house is another matter.
Jorge Castaneda
>Hi Dom,
you want rods, when they say blanks, they are already hardened and cost quite a bit more.
Funny thing I am placing an order too,
Happy holidays!
Jorge
Re: Found this on MSC
Jorge Castaneda
>Dom,
Enco carries 36" O1, I have been using that and I am satisfied, dirt cheap too, true you have to harden a nd temper it
jorge
Re: Done deal
Ed Kelle
>Dom
Good luck with the toolmaking. I am going to try making small versions of the swan neck scrapers. I used Cindy Drozda's and they worked great, she puts a neg 5� bevel on all her scrapers. She also told me that she uses the ceramic wheel for shaping the rectangle blank as it requires removing lots of material. She also made a 20� ultra fine point spindle gouge with just a flat bevel top, I will make that as well.
I used oil hardened steel for mini hollowers and went thru the entire heat treating/anealing process. Came out OK but nothing great. they do the job. I'd much rather spend my time shaping wood than metal.
Be sure to post pics of what you make. Happy turning
E
gtwilkins
>I heard about "dixie pins" from somebody and have been wondering about using them for tools. Any one used this kind of stock?
http://www.dixiepins.com/
They also have end mills that look like they might work for pens, and just about any shaped cutter you can think of.
Trevor
Pre-Hardened Drill Rod... *LINK*
Peter Teubel
>I ordered a dozen different diameter 6" lengths of PRE-HARDENED M2 HSS drill rod from Wholesale Tools (see link below) earlier year. But I cannot for the life of me find it on their web site again. You might want to call them and ask if they still carry it.
Wholesale Tool
Re: Pre-Hardened Drill Rod...
Carol from AZ
>This it?
http://wttool.resultspage.com/search?p=Q&ts=custom&w=prue%20hardened%20m%20hess%20drill%20rod&pw=PRE%2dHARDENED%20M2%20HSS%20drill%20rod&rt=spelling&isort=score
here you go... *LINK*
dwr
>... about half way down...
O-1 Drill Rod - Polished and Ground
