Mahoney Walnut oil
Mahoney Walnut oil
Mahoney Walnut oil
Don O.
>Probably been asked and answered many times here, but I need to ask again. The instructions were not entirely specific enough for my pea-brain.
When using Mike Mahoney's walnut oil on a bowl, or anything else, after wiping it on do you wipe off the excess like you would with something like Watco Danish oil ? The directions tell how to wipe it no but not whether to wipe it off or not. Should it be obvious ?
Thanks for any advice.
Re: Mahoney Walnut oil
Bert Workman
>I wipe it on generously and let it soak in. It usually takes a couple of coats before the end grain stops drinking it in. I've never had a problem with too much.
The last few coats are wiped on in much smaller quantities.
Good luck,
Bert
Don O.
>Thanks for the response Bert, but my real question is do you wipe off the excess oil between coats or just leave it all on and let it cure ? My instinct tells me to use it like watco and wipe off the excess oil and let it cure but I want some additional input from someone with experience.
So, wipe off after letting it soak in or not ? Help please.
sean troy
>Just wipe it on and let it go. It doesn't dry hard like the other oils. It's such an easy oil to use. 1 or 2 coats is all you usally need. You can wipe off any excess after awhile if you feel the need. I never had to.
Don O.
>Thanks Sean, that's just what I was looking for. Much appreciated.
robo hippy
>I just slop it on, putting extra on the end grain. Then I put a good sized gob of the wax on top of that. Let it sit over night, and then lightly wipe off any excess. Never had much left on to wipe off.
robo hippy
Don O.
>Thanks for the extra input. I don't have his wax mixture yet. I ended up wiping on a lot of oil and letting it soak in for a few hours, continually adding more on end grain where it really soaked it up . Wiped off what little excess there was and left it overnight. Looks pretty good this morning. I may see if it will take a little more tonight.
Thanks for all the help.
Sean Troy
>Just make sure to let the piece dry for a week or so before adding a top coat finish.
