Have a question? Ask Woody!
Shellawax opinions?
Shellawax opinions?
Shellawax opinions?
Bill Luinetti
>I've been using wipe-on polyurethane for awhile now, to the exclusion of almost anything else.
Over the weekend, however, I saw the work of another turner whose work was finished with Shellawax.
I've obtained a copy of the web-based information on Shellawax and the Shellawax EEE Ultra Shine abrasive paste wax, so I have that information at hand. I was wondering, however, if anyone in this forum has strong feelings (for or against) about the products.
Bill
Re: Shellawax opinions?
E Tabachek
>I use the EEE paste first and apply the Shellawax Cream over the EEE just the way the instructions tell us to do it. I get a super smooth high gloss finish that is better than Hut Gloss. BUT, I don't think it will hold up to a lot of handling. The finish seems to loose it's high gloss with only a little handling. I like its fast application and I will continue to use it. If I wanted a shiny finish that will resist handling I would go with several applications of Minwax tung or antique oil, (thin poly-u) or a gel finish that is also poly-u.
Edward
RevDoug
>I use the Shellawax combo exclusively for pens. There are some instances when a harder, higher gloss finish is desired. That's a good time for Renisaunce wax. You can also take the pen through the Beal system, finishing with the carnuba wax. You have lots of options. You nust need to experiment ant see what you like the best with what woods.
Turn 'em round,
John Kyler
>I use them both but not on pens. EEE on pens (wood and acrylics)
For pens I use French Polish.
I will say a good combo with the Shellawax is put a coat down, then use a little French polich on the rag with a little Shellawax.
I have very good results and shine.
John
Norm Smith in Nova Scotia
>I have been using the EEE and Shellawax for a few years and find that it is a great finish for small bowls, vases, etc.
Norm
Russ Fairfield
>There really isn't anything magic about either product. Shellawax is a shellac based friction polish that leaves a coat of shellac on the wood surface. As such it is neither as hard nor as durable as the polyurethane, but it is a lot faster. Do you want durability or speed?
EEE is Tripoli (get the connection - Triple E) in a liquid carrier. It is polishing compound that does the same thing as the dark Hut PPP stick or the Tripoli stick that is used with buffing wheels. Only the carriers are different - the darker Hut is Tripoli in carnauba wax and the buffing stick is Tripoli in tallow..
I'm not yet a pen turner. Plan to start
Don Henthorn
>soon though. I would never use Shellowax as a pen finish because it is a shellac. I would hate to give a pen as a gift or sell a pen that looks great when it exchanges hands and then looks grubby in just weeks. What is the enemy of a shellac finish? Water. Right??? What do your hands and fingers do if you write for a length of time or if you are in the heat? They sweat. Right??? What is that going to do to a shellac finish? You need a good hard finish, not just a shiny finish. Do it the easy way and that is what you will get. Do it right if it is worth doing.
Re: I'm not yet a pen turner. Plan to start
Russ Babbitt
>Don, what is the "right" finish? Thanks
Bill Luinetti
>Thanks for the input, turners.
For Russ Fairfield...thanks for the answer for the question, "What the heck does EEE Ultrashine stand for?"
I'll probably stay with WOP for now.
Bill
Russ, I am kind of researching that now.
Don Henthorn
>From what I have learned so far there are some turners who get big proces for their work and they have learned that some finishes are pretty and hard and other finishes are pretty. I guess cyabocrylic finshes are pretty hard and durable, but I think there are others too. I am looking into it.
